Losi 1/8 8ight E 4wd Thread
#8776
im looking for a good set up for indoor high bite clay track.... not sure where to look or havent looked far enough.. if any one could help me out it would be nice... the set up im running isnt working for me.....
#8777
#8778
I am no expert, but stiffer springs (black in back, white in front) with stock shock fluids helped me a lot. The high bite forces you into a more technical driving style, so u need more response, dont want to be sagging all over the place. Part of this is because indoor tends to be smaller/turnier as well. Also smoother tires, harder compound. Harder braking (if you run electric).
#8779
So I pulled the trigger on a used 8 2.0 Euro E conversion for $475. It has Tekin T8 1900 and RX8. Two batteries, radio and ready to go.
What are the common TLR upgrades and what is a good setup sheet to emulate here on hot florida outdoor tracks with big jumps, some loose sand in the corners and hard pack underneath?
I want to get the car set up just right before putting it under the xmas tree
#8780
This is the setup that I am using currently, this is also the recommended setup for the EU as a nitro, The only difference with mine is the rear diff is 3k instead of 2k. Drakes is also really good too. You can get both setups from the website too.
#8788
Can I use this 45T metal spur instead of the stock plastic spur?
http://www.amainhobbies.com/product_...-Spur-Gear-45T
#8789
Can I use this 45T metal spur instead of the stock plastic spur for the 2.0?
#8790
Last edited by ImGoinRCn; 01-13-2014 at 02:02 PM. Reason: I hate you auto correct!
