Like Tree5Likes
SC10 4x4 Thread
Old 08-03-2012 | 07:17 AM
  #27841
yes mip 30dollars and it makes competion and rebound ajustable i used 35w front and 30w rear you can drop it from a ft a it will botom but not bouns at all i never felt so planted on the track as long as i stay on the race line in the fluff it is the same i was ceeping pace with a gas 1/8 hotbodys last night much harder to upset the truck it looked like i had 2lb add in the truck but still nemble
9turn is offline
Old 08-03-2012 | 07:19 AM
  #27842
Wild Cherry's Avatar
Originally Posted by Cody227
Not for me. I tightened down the nut as much as possible and it didnt work. The clicker clicks even when the car is in the air (with fulltime 4WD) and i break a little bit. And the clicker is not damaged or something like that. I read often that the clicker dont work and usually they glue the clicker. There is also NO diference in handling with the locked clicker.
No way the clicker can even move
if you tighten down the clicker nut all the way ...
Go ahead , install a piece of tubing , only difference it will make is you won't have to tighten down the lock nut as far on the top shaft .
The lock nut will still lock the clicker the same as if you had no tube .
tip:
Check and make sure you assembled the clicker correctly.
Wild Cherry is offline
Old 08-03-2012 | 07:42 AM
  #27843
OldGuydust's Avatar
Smile
I constantly run across people absolutely loving the MIP realshocks stuff. I plan on getting the valve kit and sticking it in. easy to understand how it works and I like the finite adjustments made available. $28 at amain and free shipping , woohoo. Thats just one day of PBJ for lunch lol!
Anyone have some good hint , tricks, or findings on how these parts have worked for you?
Thanks!
OldGuydust is offline
Old 08-03-2012 | 07:56 AM
  #27844
Thanks!
whach bk get his ass spanked
http://www.youtube.com/watch?v=bMAAc...layer_embedded
they give you the right shims to start but i would like to try the harder stack with liter oil maybe 30w f and 27.5w r with 2.4 or 2.5 stack it come with 2.1
9turn is offline
Old 08-03-2012 | 07:58 AM
  #27845
im going down to my track to see it i can brake in to the 17s be back in 30min
9turn is offline
Old 08-03-2012 | 08:07 AM
  #27846
What am I really looking at here besides the leader being faster. The cars don't appear to handle any different from one too the other. One driver just seems better too me.
RC-1 is offline
Old 08-03-2012 | 08:10 AM
  #27847
Yeah , Easy to tell who can drive and Bk usually
only practices one or two packs .....
Old 08-03-2012 | 08:15 AM
  #27848
@WC: sorry, with fully tightened i meant as much as possible with the spring. So a bit more than 3mm, maybe 4 or 5. Now i tightened it 3mm as shown in the manual and the clicker definitely moves! i can even see it move, so it can't be the belt or the diff. The clicker pulley driver has a bit damage, but not much.
Cody227 is offline
Old 08-03-2012 | 08:35 AM
  #27849
Wildcat1971's Avatar
Tech Prophet
tighten the nut until it no longer turns
Wildcat1971 is offline
Old 08-03-2012 | 10:50 AM
  #27850
Sounds like you have already worn off the paws on the gear ....
A tight lock nut will not hold if the gears are worn out .
glue it if you don't have a replacement & need full time 4w drive
Old 08-03-2012 | 10:51 AM
  #27851
fq06's Avatar
Talking
Nothing related to the sc10, just sharing my misery.
Car wouldn't start this morning.
Check battery first, all good.
Maybe the AEM EMS needed to be reset and reflashed. Nope.
Thought it may be the clutch disengagement sensor (tells CPU your clutch is pressed in) so I jumped the two wires to trick it into thinking the clutch was in all the time. That required me doing a head stand in the foot well trying to get at it buried under the dash. Cussing and banging ensued.
Got it and not change. Not a click or anything to indicate that the starter is getting any power.
Thought for a second and thought why didn't I try this to begin with before I had bloody knuckles?
Starters right under the top intercooler pipe at the back of the motor so an easy target for a small hammer. Tapped it a couple times and tried it out. Started right up, leaving to get a new starter now
fq06 is offline
Old 08-03-2012 | 10:53 AM
  #27852
Originally Posted by J61092
Loose as in my tensioners are maxed out an that keeps it just barely tight enough. I thought that when I threw a new belt on that it would tighten things up an I would have to loosen my rear tensioner but nope I still have to have them both maxed out to keep the belt just barely tight enought. By barely tight enough I mean tight enough to run, skips a little but could be a little tighter.
thats odd. can you take a pic with the covers off ?
twisted is offline
Old 08-03-2012 | 10:59 AM
  #27853
OldGuydust's Avatar
Cool
Wow!!! That is som friggin nice driving!!! Make me look like dooooodooooo...
His nose was heavy up until 3:11, but at 2:58 was a nice drift and after that , super smoothness came to the party... It handles nice for sure.
Old 08-03-2012 | 11:03 AM
  #27854
TEAM-AE-4-EVER's Avatar
Originally Posted by twisted
6mm worth of spacers plus the shock boot. if youre not using the shock boot 8mm of spacer.
Wow!
8mm of spacers on the shock shaft and outside the shock body is a bit more than I expected to avoid outdrive problems...
TEAM-AE-4-EVER is offline
Old 08-03-2012 | 11:06 AM
  #27855
Originally Posted by TEAM-AE-4-EVER
Wow!
Works great , still have the same amount of suspension travel too .
