Like Tree5Likes
SC10 4x4 Thread
Old 08-01-2012 | 01:36 PM
  #27676
ryanpatrickgore's Avatar
Yea not a whole lot of shiny goodies for this truck. Been said before...
Red headed step child
ryanpatrickgore is offline
Old 08-01-2012 | 05:41 PM
  #27677
scr8pn4205's Avatar
New to the sc10 4x4. Wondering on the outdrive wobble fix, the xray shims to replace the stk ones the way to go or is there a better solution. Also is this only for the rear diff or is it needed for the front also??? What other mods are necessary to make the truck better.
scr8pn4205 is offline
Old 08-01-2012 | 05:59 PM
  #27678
Wildcat1971's Avatar
Tech Prophet
How long did it take them to wobble? Mine are tight
Wildcat1971 is offline
Old 08-01-2012 | 06:01 PM
  #27679
fq06's Avatar
Fix wobble with the xray shims, the 0.3 thickness shims f&r.
AE also has updated 0.5 shims.
Prevent future wobble by limiting shock up travel with 5mm of shock clips f&r..
fq06 is offline
Old 08-01-2012 | 08:01 PM
  #27680
im putting in a transponder and running out of room. it should count if i have it over the servo , shouldn't it ?
twisted is offline
Old 08-01-2012 | 08:13 PM
  #27681
ilanstylz's Avatar
If you mean the top plate the servo mounts on yes that is where I currently have mine mounted........
ilanstylz is offline
Old 08-01-2012 | 08:18 PM
  #27682
yea that spot. its one of the last places i could mount mine.
twisted is offline
Old 08-01-2012 | 08:20 PM
  #27683
ilanstylz's Avatar
I put mine there or on top of the rear tower.........
Old 08-01-2012 | 08:48 PM
  #27684
Jake S's Avatar
if you have an MRT PTX or Mylaps:
if you have the old Red AMB then the best spot is on top of the top plate above the servo, or just ontop of your RX like BK does.
Jake S is offline
Old 08-01-2012 | 09:09 PM
  #27685
Tech Prophet
mine is on the belt cover......
Old 08-01-2012 | 09:20 PM
  #27686
Wild Cherry's Avatar
If you can get the new Ae .5 shim kit...
or
you can also use
2 x .2mm of the large shims under each sungear & remove the small outdrive 2mm shim & assemble ....( works great )
*Do both the ft & back diff's same way
*Remember to install .8mm external limiter on shock shafts to help protect outdrive cups from CVA bash....
Other mods ?
Team upgrade kit # 91174
#1 upgrade
Cain , under stand completely your view and sorry for the only use "Ae" tune .
That part is a very good part & its performance is great .
More than I say for some of the other aftermarket parts you can buy .
Even have two teammates using .....
Wild Cherry is offline
Old 08-01-2012 | 09:22 PM
  #27687
BlueGlowBoy's Avatar
it all depends on your track and how deep the loop is buried, and how sensetive their system is set.....
we had a guy that was missing every 2nd or 3rd lap because his transponder was set on top of the center diff on a slosi.....but everyone else was good.
BlueGlowBoy is offline
Old 08-01-2012 | 09:31 PM
  #27688
I doubt the shims alone will fix the wobble, as the bushings are what wear out.. I did the bearing mod and there's almost no wobble now.
Arakon is offline
Old 08-01-2012 | 09:35 PM
  #27689
If you start out with
new diff cases &
the 2 extra shims & including the external shock limiters ?
The out drive cups stay snug & less slop with wear...
no real need to mod the diff cases, not diss the mod , just saying ...
Old 08-01-2012 | 09:43 PM
  #27690
arggggh !
so as some know im going to the sc nats. ive been redoing my truck and so on. following their rules to a "T".
then i read on their FB page just a bit ago that you can not cut holes in the windows or any unmarked area on the body. this was posted by one of the track guys...
BUT.. on their rule file download (the one ive been going by) it says no such thing and guess what i did to a brand new body ? yup cut holes in the window... and in the rear.
i copied and pasted their rules on that comment and im waiting to hear back from them. it ticks me off a bit...
sorry for the rant.
twisted is offline
