Like Tree5Likes
SC10 4x4 Thread
Old 07-25-2012 | 07:06 PM
  #27106
does that cure the problem ? i read that some suggest an external BEC which doesnt make sense to me if you can up the voltage of the one in the esc.
thanks for the help.
twisted is offline
Old 07-25-2012 | 07:09 PM
  #27107
fq06's Avatar
Amp draw is the problem, not voltage. You can have brownouts with 5 volt or 6 volt settings.
1258's can draw 5 amps at 6 volts stalled out.
Most servos draw 3 to 4 at stall
Edit:
4 amps at 4.8 volts... hmmm, I see where others may not have had a problem with their rx8 if at a lower volt setting
But then your also not getting the most out of your servo at less than 6 volt anyway.
fq06 is offline
Old 07-25-2012 | 07:16 PM
  #27108
Wildcat1971's Avatar
Tech Prophet
I refuse to use savox or spectrum products because of these types of issues. Airtronics ftw.
Wildcat1971 is offline
Old 07-25-2012 | 07:19 PM
  #27109
ryanpatrickgore's Avatar
+1. ^
I turned the bec all the way up on my old mmp. Didn't make any difference at all.
ryanpatrickgore is offline
Old 07-25-2012 | 07:30 PM
  #27110
ilanstylz's Avatar
Hmmm I run both savox and spectrum and only time I had an issue was when I ran it with my mmp. For the prices you can get a good used savox I will def. keep using them. However best servo I own and would like to buy more are the radiopost servo's............
ilanstylz is offline
Old 07-25-2012 | 07:33 PM
  #27111
Maddog94's Avatar
This ^^^
Everyone blames the Savox servos, but IMHO, it's the MMP piece of dogshit that's the problem.
Maddog94 is offline
Old 07-25-2012 | 07:34 PM
  #27112
Tech Prophet
Well that is kinda the issue. Savox, MMP and SPektrum are probably the most common amongst the non pros. And together they are an issue. I have also heard the Savox give issues to the Tekins and LRP's also.
Old 07-25-2012 | 07:35 PM
  #27113
Scottmisfits's Avatar
Thankfully I haven't had the issue of the Savox Brownout but I have helped a few people that have. A glitch bust should be all that is needed.
I am running mine off of an LRP SXX TC spec v2. I know the LRP's have a higher amp internal BEC than most other manufacturers so maybe this is why I haven't seen the issue.
I run a Savox in one truck only right now, just as a tester from Savox and I do like it. All of my other servo's I use are the AE 1015's. Great power, great speed, great price.
Scottmisfits is offline
  #27114
Tech Prophet
Well the savox are not the most efficient servos. They just have a nice price point.
Old 07-25-2012 | 08:08 PM
  #27115
Originally Posted by Maddog94
This ^^^
Nope. It's the Savox. That being said I still run Savox in all my vehicles. It's even an issue with my rx8, however all I need is a cap to make things work, unlike mmp I had to have a external bec. I ran a few different servos with my mmp and spectrum and had no probs. but take any one of those 3 items out of the equation and pribs solved. I battled this and trouble shooted for over a year.
Old 07-25-2012 | 08:09 PM
  #27116
Agreed mmp do suck tho.... Haha
  #27117
couldnt you just bypass the esc's bec and draw directly from your main lipo ?
twisted is offline
Old 07-25-2012 | 08:11 PM
  #27118
That's kinda what the external bec does ... So yes.
Old 07-25-2012 | 08:12 PM
  #27119
fq06's Avatar
Yeah, the worst part about it is that I had a replacement case at home for the airtronics that broke. I just needed toget through the night.
Turned out, I didn't get farther than the first turn in the main and pulled off the track to get out of the way.
fq06 is offline
Old 07-25-2012 | 08:17 PM
  #27120
Maddog94's Avatar
LMFAO: as I read this thread, the flashing banner at the bottom of the page is for Savox Servos!
Maddog94 is offline
