SC10 4x4 Thread
Diff grinding issue revisited........
I placed the shimms in the planet gears as recommended and it was to tight, so I removed the out put shaft and placed another sun gear shim on one side going from .2 to .4mm under the sun gear this eliminated the issue. I talked to team associated about my fix and he said it needed to be .5mm under the sun gear and they will send me the correct shimms. The old shimms were inadequate so they are puting out the .5 and sending them for free. That's why everything I have is associated, this may have been brought up a while ago, but goo info to revisit.
I used forever till I got the new gear cases & .5 shim included with.
Pulled a late nighter and got my FT SC10 4x4 restuffed with it's RX8/4600 Pro4, and a Spektrum 6040 servo (best servo for the money imo that's capable in a 4x4 corr truck). Wasn't worth selling for next to nothing so I put a few bucks into a servo & receiver and figured why not keep it? Of course it won't earn my Tekno a spot on the bench
but I'll take it out for a heat here and there. Almost forgot how much fun it was to put a servo in this thing
. Oh well. I did like the truck quite a bit so the old girl is worth holding onto.
. Oh well. I did like the truck quite a bit so the old girl is worth holding onto.I'm going to set mine up so my buddies who aren't really into racing can come out every now and then and run with me. Makes me feel like a NASCAR team owner
There is also a super small dirt track opening up about 15mins from my house they normally run Friday nights so will be a great warm up race before heading out to the big outdoor tracks on Saturday.
Keep Dreaming...
As Cherry pointed out at the HotRod. 4x4 SC is really nothing in this hobby. It's a toy class in most eyes. 2wd SC is MUCH more respected than 4wd. There isn't an drive to advance the class, and as such no incentive to produce new products. This chassis is all on you guys and your brilliant engineering to make things work. (till they pull out of their butts and allow conversions and 3s. HAH!)
For the record: I'm dreaming with you. =)
Its the next best thing in outdoor racing (electric), with 8th scales, or on 8th scale tracks. My B4.2 and T4 will never see an 8th scale track, to hard on them IMO. Plus there not fun to drive, to me, on rough 8th scale tracks. Plus the shear size of the tracks now days, i cant even see a 10th buggy on some tracks.
Anyway, I think some MFR's, AE, are asleep at the wheel on this class. Now that Tekno and TLR have stepped it up, then you have some other nice entries, Caster etc. AE could bring a new truck into the class and it very well could climb the ranks, and sell alot of kits.
I'll run mine, and fun, i think there a blast to drive.
I know not really the thread for this but maybe someone can help. I'am having brown out problems in a sc10 4x4 havoc pro w/X & super tuner (5amp bec) and just installed a schuur speed 4 pole 4800kv. My transponder is not counting. At one track loop is just before a huge double and you have to goose it hard. I can see the transponder light flicker on the car stand, must be worse under load. Everything seems fine with a novak 550 though.I do have a glitch buster but connected or not doesn't seem to make any difference. Any ideas?Servo does not seem to be glitching though
Hey man looks real good! Do u have your setup posted or do you mind posting it? Thanx
Out doors would recommend the covers if you are running on a back yard track with 2 in of dust to plow .
Most outdoor tracks are better & groomed ,so I would not use the covers still .
Candrell has raced this summer outdoors on what most consider a typical outdoor event that has mass dust ect. He had no problems.
I have not raced outdoors for a couple years now . Use to race the big outdoor events all summer for many years , raced 1/8th & gas truck .
These days I like to stay near home and save money .
Competition at Trcr is so intense , so no need to travel when I can get beat at my local by factory drivers ....
Hey man, I run that same esc in my sc10 4x4 and I really don't think it is rated for a motor that pulls such large amounts of power. Think that goes for any 4 pole motor, I run a reedy 550 4.0 and I'm having over heating issues with the esc, I'm using a 13/62 and I run it really hard (racing no bashing) I just upgraded to the hobbywing sct pro esc and xerun 4700kv 4 pole because again I don't think that esc will handle the load and that is why it is cutting out on you, the motor pulls so much not enough power can go to bec and receiver, call novak to be sure
I talked to Charlie and it is rated for 4 pole motors, he says its probably a bad solder joint or something causing a huge draw I just hope i'm not getting the run around everybody blames the others equipment. I just want to solve the problem how ever I need to. Searching around though I have even seen racers with rx8 having the same problem so I'm going to try rewiring and swapping the servo. I do use those 3.5mm bullet connectors on the motor wires does anyone know if that's a good idea??
5Likes
