SC10 Thread
Old 05-19-2012 | 12:00 PM
  #12001
mxracer458's Avatar
Originally Posted by Murray100
I had the same super customer service from associated. My esc went bad at 90 days and they replaced with new esc and motor. Go Associated.
yep and thats why ill stay a loyal ae customer
mxracer458 is offline
Old 05-19-2012 | 01:13 PM
  #12002
Originally Posted by idrummerboy13
ganna grab one of these from the shop once my 4wd is sold....for indoor med bight clay all around I always hear gold barcodes are great, last forever and have good grip. Would pressure points in gold work well also?
For the 2wd buggy blue v1 works perfect.
I have been running pressure points for the last couple weeks. I am going back to barcodes, they seem to give me more side bite
rm25x is offline
Old 05-19-2012 | 01:24 PM
  #12003
idrummerboy13's Avatar
ok thanks, glad to hear from you again, hope all is good. Your screws have been sick.
The track has a lot of blue and gold, I will just grab gold all around. OH yea
how are you 17.5 timing only guys gearing? i think it is about 25 75 no? All timing or no? help!! lol i never really ran 17.5 much and when I did it was terrible rtr. lol
idrummerboy13 is offline
Old 05-19-2012 | 01:27 PM
  #12004
LeeBSC10's Avatar
Are rear sway bars a good idea? I will be racing on an indoor carpet sc track with small jumps. Also what are some good tires for running on carpet?
LeeBSC10 is offline
Old 05-19-2012 | 02:18 PM
  #12005
EDIT: NVM got to looking closer and they are different.
stang is offline
Old 05-19-2012 | 03:00 PM
  #12006
Rear sway bar is a good idea, also some guys are running the rear up front too with some customizing for less chassis roll. I haven't tried running them yet, but I am on the clay though. Carpet has a lot more traction.
Thanks Guy, glad to be back from my 30 day time out...
rm25x is offline
Old 05-19-2012 | 07:11 PM
  #12007
eper's Avatar
Originally Posted by Brushless420
I have run a ton of LRP motors and can tell you from personal experience that they always run hot. LRP motors will run typically 20 degrees hotter than most anything else. They are fine in the 180 range. The only thing you should always remember to do on the LRP motors is bearing maintenence. Make sure your checking them and oiling them as needed. Also helps to keep some spares on hand.
thank you for the response, i'll run it till it melts haha
eper is offline
Old 05-19-2012 | 08:29 PM
  #12008
this is the opposite experience i have had. my tekins( 17.5, 13.5) has run hot, while the lrp(10.5) I have is ice cold. were talking its seen 140 max thats while shoving timing through it like no other.
stang is offline
Old 05-19-2012 | 11:42 PM
  #12009
Cloaked's Avatar
So my SC10 has now done about 2 hours worth of track driving and been cartwheeled many a time, node dived plenty of times and even done its impersonation of a turtle many a time.
To my amazement nothing has broken! But to be prepared what sort of parts should I have on hand in case something breaks. Im starting to race next weekend and want to make sure I can make it to the main.
Cloaked is offline
Old 05-20-2012 | 06:15 AM
  #12010
???E-Racer's Avatar
Cloaked- Yeah the only upgrades I did to mine and it has made the truck
more durable for 1/8th scale type tracks with huge jumps is RPM A-arms
with the RPM front bulkhead combined with an RPM front bumper with the GT2 hinge pins.
I highly recommend the RPM plastic over anything aluminum.
It will make the truck not only more durable, but do so without adding too much weight.
Ive ran it like this for several months now and have not upgraded the rear end.
The rear is well protected anyhow because of the big bumper they put on these Corr trucks.
Aluminum upgrades are only for the "Bling" factor.
???E-Racer is offline
Old 05-20-2012 | 07:33 AM
  #12011
bds81175's Avatar
Moderator
If you have a locked servo saver you might want to have a couple of extra servo horns on hand. They don't break often but it can happen. If you replace the servo horn with an aluminum one, you will want to have extra caster blocks and steering knuckles because that then becomes the weak link.
bds81175 is offline
Old 05-20-2012 | 07:56 AM
  #12012
vfrninja's Avatar
Lower arms, ball cups, wheel nuts, and body clips are all good to keep spares of. It's also smart to have some extra bearings for the wheel hubs.
vfrninja is offline
Old 05-20-2012 | 09:07 AM
  #12013
gamedog1966's Avatar
hey there u guys, i have a small prob that i would like to address with my truck. the truck feels good overall but the steering seems to b a little too sensitive for me like after a turn it still may want to oversteer a little bit. what should i do. i have the latest mayfield setup on it
gamedog1966 is offline
Old 05-20-2012 | 09:09 AM
  #12014
Acill's Avatar
And once again go to ebay unless you have a local shop that you love! You can find the "chop shop" guys selling things in section, like full front end, full rear end, chassis and bumpers for like 1/4 the price of most shops.
All last week I ordered repair parts to have on hand and I now have nearly two trucks in spares for under $100
Acill is offline
Old 05-20-2012 | 10:12 AM
  #12015
J_Bone's Avatar
Originally Posted by gamedog1966
hey there y guys, i have a small prob that i would like to address with my truck. the truck feels good overall but the steering seems to b a little too sensitive for me like after a turn it still may want to oversteer a little bit. what should i do. i have the latest mayfield setup on it
I'm running a setup based on the Maifield setup and changed a few things.
  • I used my Radio for the first adjustment. I had to run -50 expo to slow down the initial movement.
  • I took out one bump steer washer. From .060 to .030, or 1mm to 2mm. This took out the twitchyness I was having on the bumpy corners and corrections after jumps.
Other options that can help; caution that too many changes can totally ruin a setup and one change should be done at a time.
  • On the front shocks, move the upper mounting to the middle hole.
  • On the front shocks, use heavier oil.
  • More negative camber in the front. That will give less side bite.
  • Running a less aggressive tire. Sometimes I run a tire that is worn down a bit.
Hope some of those will help.
J_Bone is offline
