SC10 Thread
hey there u guys, i have a small prob that i would like to address with my truck. the truck feels good overall but the steering seems to b a little too sensitive for me like after a turn it still may want to oversteer a little bit. what should i do. i have the latest mayfield setup on it
What j-bone posted is dead on - but will do no good with a slow servo.
This winter I ran stock sc10 tires up front and losi strike tires in the rear with closed cell foams all around. Also put a small strip of foam in the strike tires for outer sidewall support. Truck hooked very well and was close to traction rolling. Just about everybody at the track ran this same setup.
And once again go to ebay unless you have a local shop that you love! You can find the "chop shop" guys selling things in section, like full front end, full rear end, chassis and bumpers for like 1/4 the price of most shops.
All last week I ordered repair parts to have on hand and I now have nearly two trucks in spares for under $100
What servo are you running? I had the same issue with the slow stock servo. Went to a new Savox servo and it got rid of the latent steering. I then went to a Futaba 3PL radio and rx and the steering improved even more.
gamedog1966 ---- 1st thing to do is check your sensor wire....If that goes out (at least with a SP Cirtix esc) it will delay braking but forward will run normally. Happened to me the other day and I found a bad spot on my sensor cable.
I have finally got my FTSC10 dialed and have bought every go fast part avail. but seems like to 17.5 class is dying at my local track and I was wondering if the same thing is happening at other tracks? We seperated the 2wd SCT class at the beginning of the year into Novice and also 17.5 Sportsman/Pro so we have 20-25 novice every race but only 5-10 17.5 trucks. Anyway I think we are going to do a open 2wd instead of 17.5 which I think takes away some of the fun also cost more to be competitive. Anyway how is the 2wd SCT 17.5 class doing at your local track?
I thought our track was rough... That second pic almost looks like a crawler
