SC10 Thread
Old 05-17-2012 | 08:19 PM
  #11971
vfrninja's Avatar
Originally Posted by Lake Ober
Ok, so your saying I should remove the 2 shims that I have on each of the rear axles, and the 1 shim I have on each of the front axles... essentially the adapter will rest against the bearings? Correct? And what were you saying about getting F.T. pins? I'm running a Factory Team truck, do I need to change them then? Thanks!
Correct.
The stock roll pins can bend. These are easier to get on and off too.
FT axle pins.
vfrninja is offline
Old 05-17-2012 | 09:27 PM
  #11972
Lake Ober's Avatar
Originally Posted by vfrninja
Correct.
FT axle pins.
Great, thanks for your help! I just wrote down the part# for those solid axle pins and will pick them up when I go to the track on Tuesday
Lake Ober is offline
Old 05-17-2012 | 09:33 PM
  #11973
Cloaked's Avatar
Anyone had any experience with the Spektrum DX3C?
Going to pick one up this arvo.
Cloaked is offline
Old 05-17-2012 | 09:41 PM
  #11974
Suspended
yeah i have i got one and i love it very good for it price
Zangetsu is offline
Old 05-17-2012 | 09:46 PM
  #11975
Just some fore warning, mine did not want to stay in when I had the wheel off. I lost a couple due to this. What I ended up doing was putting some blue loc-tite on the pin and then sliding it in. After the loc-tite set up it was perfect. I could still take it out easily if I wanted to, but it would not fall out just sitting there.
cody161 is offline
Old 05-18-2012 | 02:31 AM
  #11976
eper's Avatar
I'm running an lrp 9.5 in my sc10,whith the tc spec v2 esc. i have a 87 tooth spur with a 19 tooth pinion and i'm having heat issues. the timing in the motor is at 30degrees. the tranny is free of binding. i'm also running the same weight in the truck as the maifield setup anyone have any ideas y this truck is running this hot. its definetly over 160 at about 5 minutes
eper is offline
Old 05-18-2012 | 04:26 AM
  #11977
Cloaked's Avatar
Hi All
I just have a question with wiring up my SC700-BL ESC , my Spektrum SC300 RX and my NiCD reciever battery.
Now I know when running an external UBEC you disable (either cut or remove) the Red (power) cable from ESC to RX.
My question is... is it the same when using a seperate RX battery? Do I still disconnect the red cable?
Never used an RX battery before.
Cloaked is offline
Old 05-18-2012 | 06:25 AM
  #11978
vfrninja's Avatar
We're using these pins with the hex adapters. If your using pin style wheels just a touch of silicone rtv works well too.
vfrninja is offline
Old 05-18-2012 | 06:34 AM
  #11979
AErckidd's Avatar
Anyone have any ideas for outdoor setups? Ive only raced indoor clay but theres a big outdoor race this weekend that I'm going to and have no idea where to start. Shock oils? Springs? Gear ratios? Weight in truck? Ill be running a 10.5 fully boosted on a wide open track with a lot of big jumps. Its hard pack, dusty and bumpy. Thanks guys
AErckidd is offline
Old 05-18-2012 | 06:38 AM
  #11980
vfrninja's Avatar
Originally Posted by Cloaked
Hi All
I guess I would ask why your messing with a rx Batt. I'm not familiar with the esc your speaking of but most escs have a built in bec to power the rx and servo.
If you do use a separate power source (external bec or rx Batts) to power rx and servo then yes disconnect the red wire from the esc otherwise you'll have double the voltage to the rx.
vfrninja is offline
Old 05-18-2012 | 06:47 AM
  #11981
Cloaked's Avatar
1257TG Savox Servo causes the SR300 RX to brown out under heavy load.
Common occurrence.
Cloaked is offline
Old 05-18-2012 | 08:07 AM
  #11982
matt*strike's Avatar
I use that same setup as far as esc and servo with a sr300 and haven't had any problems so far if so you can just buy a cap that plugs into the rec and stops all your problems
matt*strike is offline
Old 05-18-2012 | 08:57 AM
  #11983
Lake Ober's Avatar
I just watched this video of some cool 3M brand carbon fiber vinyl. Thought it may be cool to utilize it on a R/C project in the future for some cool styleee
Click Here To Watch
Old 05-18-2012 | 12:42 PM
  #11984
Brushless420's Avatar
Default heat
I have run a ton of LRP motors and can tell you from personal experience that they always run hot. LRP motors will run typically 20 degrees hotter than most anything else. They are fine in the 180 range. The only thing you should always remember to do on the LRP motors is bearing maintenence. Make sure your checking them and oiling them as needed. Also helps to keep some spares on hand.
Brushless420 is offline
Old 05-18-2012 | 12:47 PM
  #11985
Common occurrence.
Before you do that try one of these http://www.amainhobbies.com/product_...rce=google_ext
Most of the time this will be an easy fix. However sometimes those SR300 receivers are a PITA. If you have another RX available to run try swapping out that SR300.
