SC10 Thread
Old 05-16-2012 | 09:57 AM
  #11941
weavty1's Avatar
Originally Posted by samlax77
Does anyone think that it's worth it to change everything to the 12mm hex style? Do you think that there would be any change in handling or speed? Or is it just an option for accessability reasons?
It's primarily for a broader/easier tire and wheel choice.. That way you can rotate your tires, should you be running hard-packed clay/bluegroove, as well as only have a box or bag of one type of wheel/tire.. Instead of having your Fronts separated from your rears.. Just makes things easier all around.
Rock on man, cheers!
weavty1 is offline
Old 05-16-2012 | 10:00 AM
  #11942
weavty1's Avatar
Originally Posted by brent701
Plus the SCT class is getting out of control with hacking and bad driving.
Heh, wouldn't have to worry about that, if you stayed out front! lol jk jk
weavty1 is offline
Old 05-16-2012 | 10:37 AM
  #11943
J_Bone's Avatar
Originally Posted by Lake Ober
Thanks for your help guys! Good, I'm glad to hear that it's not impossible to have my CVD's still be good 7 month's after I built it. But, I'm sorry to hear about yours J_Bone, I sure wouldn't be too happy if I had to replace mine that often. That seems weird that they are failing so quickly, I just wouldn't have though they'd go bad that often. What was going wrong with them exactly?
I'm not sure what's happening. I've checked bearings, gears and everything attached. don't have an answer. I just keep an eye on them after every run.
Just wanted to double-check...
I just received my Avid front/rear 12mm hex adapters today in the mail, to replace my stripped out JConcept pieces-o-crap. I installed them the same in the rear as the Jconcepts were (removed blue cone-shaped space, and left the 2 shims on the axle). And in the front, I left the one shim on the axle. To the guys running the Avid hex adapters: is this the correct way to install these?
I don't quite understand why Avid doesn't include any type of instructions in the package with their items, or on their website. I mean... I know they are pretty simple items, but it still would be nice to make sure I put them on right.
I will say though, I was actually able to put the adapters on the axle and tighten the screws without stripping them out. WAY TO GO AVID!!! You figured out how to make a hex adapter for the SC10 that actually works... now help out JConcepts a bit, so they can stop ripping people off with their junky adapters
I don't use any shims in mine. I installed mine with new hardened pins and the hexes but up perfect the bearing and there is minimal slop. 1 shim is to tight on mine. I'm also running the .5 offset B44.1 hubs. Not sure if that would make a difference?
J_Bone is offline
Old 05-16-2012 | 01:25 PM
  #11944
Brushless420's Avatar
Thumbs up 12mm hex
There will be no direct effect on handling or speed. The advantage comes in the wider range of wheels you can use along with not needing 2 seperate style wheels for the front and rear. Another plus is the ablity to use the +3mm offset wheeels available in 12mm hex.
Brushless420 is offline
Old 05-16-2012 | 02:01 PM
  #11945
brent701's Avatar
Trust me. I have no problem staying in the front.
It's when you get hacked the 1st turn when you start or when you come around to lap drivers that want to race you and push your door in as son as they get a chance to..
Became to much to deal with so I stopped for a while.
I can dish it back though. without a problem. It seems when someone wants to push you around the track and they get pushed back. all hell breaks loose and the crying starts. lol kind of funny really.
brent701 is offline
Old 05-16-2012 | 02:12 PM
  #11946
weavty1's Avatar
Oh, yeah I know the feeling man! Happened to me just this last Friday night, running Open 2wd SCT.. lol, came around to lap the 2nd, 3rd, and 4th guys, and immediately was thrown off the track by them all wanting to take the same line as me, on a 90° corner hip jump.. It happens though.. meh
weavty1 is offline
Old 05-16-2012 | 02:36 PM
  #11947
brent701's Avatar
That it does.
brent701 is offline
Old 05-16-2012 | 02:44 PM
  #11948
J_Bone's Avatar
That it does.
Every race it seems to happen. That's why I've considered switching to 2wd buggy.
J_Bone is offline
Old 05-16-2012 | 02:52 PM
  #11949
brent701's Avatar
Yes sir. That is why I do Buggy and my T4.1
brent701 is offline
Old 05-16-2012 | 06:01 PM
  #11950
RCNurse's Avatar
Well that's why race directors should speak up and make the offenders wait till the offendee is back on the track.
Oh, I just got home with my new FT kit!
RCNurse is offline
Old 05-16-2012 | 06:43 PM
  #11951
mxracer458's Avatar
i race stock buggy and the time before last it was full of short course drivers wanting to try buggy,i was tq in stock buggy,got ran over i don't know how many time and had to work my way back from last place at least twice,ii ended up 6th place on the night,really frustrating.
mxracer458 is offline
Old 05-16-2012 | 08:12 PM
  #11952
RA99GT's Avatar
SDRC right? Ya I was in that same race bumping up from the B. I watched a group of cars in front of me taking each other out, allowing me to cruise by and finish 3rd I think.
But ya, I quit racing SC 2 years ago because all the hacking is frustrating.
RA99GT is offline
Old 05-16-2012 | 08:39 PM
  #11953
mxracer458's Avatar
Yup sdrc,my qualifiers were really good,lined up for the main and they ran me over like a train coming through lol,I like sdrc alot,just a few bad apples there with some really bad attitudes,lots of really good guys also that Ive met.hoping my job situation turns around so I can come back racing.
Old 05-16-2012 | 09:14 PM
  #11954
Cloaked's Avatar
Question of Removing Tyres?
What is everyones favourite method?
Boiling/Baking/Acetone?
Im thinking of taking the lazy mans acetone path.
Cloaked is offline
Old 05-16-2012 | 09:18 PM
  #11955
J_Bone's Avatar
Acetone...Going to drop in 4 sets next week.
J_Bone is offline
