Like Tree5Likes
SC10 4x4 Thread
Old 04-15-2012 | 05:09 PM
  #21481
SCTDan's Avatar
Originally Posted by JEFFs SC10
Hartson and Numedahl are 1 and 2 at Mike's Hobby Shop in 4wd SCT.
Marcus is #10.
Hartson is TQ in 3 classes, dude's on fire. Kody's is TQ in 2wd SCT.
I think the AE boys are looking to make a statement. Wish I could watch the races live.
Not to squeal on Marcus but I think he switched to his Durango after 2 qualifiers
SCTDan is offline
Old 04-15-2012 | 05:16 PM
  #21482
Farmer_John's Avatar
Man, it's been peaceful and quiet in this thread for quite some time...Good info for sure, without the chest thumping at that!
Farmer_John is offline
Old 04-15-2012 | 05:36 PM
  #21483
Resqnu's Avatar
Default Many thanks
Originally Posted by SCTDan
When I ran the MTK basket I liked 20/5 for our outdoor track. If you have extra front springs you may want to try white or blue front springs on the rear and go up to 30wt. It will jump better and have better on power steering. I run my ride height at 24 to 23 mm. Helps stability in big sweepers and high speed turns. Have you spaced up the inner ball studs of the camber links? if not try 4mm front and rear.
Originally Posted by Evil Genius jr.
Different spring rate, they are much stiffer and equalize the f/r wheel rate.
Definitely get blue front springs for the rear. Depending how technical the track is , go 10/5 or 20/5
I encourage you to get a center diff.
Just want to say thanks for the info. I am back in love with my truck this weekend....lol. I set the truck up per you guys recommendations and ... WoW. It was awesome. But I only had 2mm of spacers for the ball studs. I have some on order to try the 4mm. If the center diff and 2stage pistons will make it even better, then I am in for them..
Thanks again!
Resqnu is offline
Old 04-15-2012 | 05:40 PM
  #21484
I just purchased the hi-tec hs-4646water proof servo for my sc4x4 and the wire from the servo to the receiver comes out of the side of the servo getting in the way of the servo mount . any ideas on how to get around this or should i just return it and get another sevo? and what type of servo do you recommend? trying to stay around $50.
thanks
schile is offline
Old 04-15-2012 | 05:47 PM
  #21485
SCTDan's Avatar
For those wondering how the diff mod with the extra bearing holds up I can say it's worth it. I had close to 10 hours run time on my front diff and it was still a 1/4 full. Action was still good but I new the oil would be nasty. Cleaned it refilled it. No significant wear on the bushing. Just replaced the seals on the outdrive and called it good. Even the washer under the sun gear was fine. I'll probably have to wear out the teeth on diff housing before replacing it.
now to read up some more on that Durango I have coming
SCTDan is offline
Old 04-15-2012 | 05:50 PM
  #21486
SCTDan's Avatar
Thanks again!
Go to the hardware store and get some 3mm nuts to thread on the ball stud. That will give you about 2.5 mm. Add from there.
SCTDan is offline
Old 04-15-2012 | 05:51 PM
  #21487
Is there a thread somewhere that has the mods listed? 1430 or so pages is a lot.
truraza is offline
Old 04-15-2012 | 05:54 PM
  #21488
Evil Genius jr.'s Avatar
http://www.ultimaterc.com/forums/sho...d.php?t=137386
SCTDan let me know how that durango is, looking into getting on to run along with my SC10 4x4.
Evil Genius jr. is offline
Old 04-15-2012 | 06:38 PM
  #21489
SCTDan's Avatar
Will do. Waiting for Marcus to send my V2 diff upgrade and then get some run time and maintenance on the Durango for comparison. I really only have one track to run on so it will be limited. Both will have comparable upgrades and be run back to back by a couple different people.
SCTDan is offline
Old 04-15-2012 | 06:39 PM
  #21490
kingkole's Avatar
thanx Evil Genius jr for the link to the thread you mad it is alot of help
kingkole is offline
Old 04-15-2012 | 07:40 PM
  #21491
Wow guys!!! Durangos huh??? Very sad
rickybobbyxxx is offline
Old 04-15-2012 | 08:04 PM
  #21492
kingkole's Avatar
+1
kingkole is offline
Old 04-15-2012 | 08:25 PM
  #21493
SCTDan's Avatar
Just adding to the stable. Not like I'm trying to convert a RC8.2e or something
SCTDan is offline
Old 04-15-2012 | 08:38 PM
  #21494
lol
bolt speedmen is offline
Old 04-15-2012 | 08:40 PM
  #21495
At least im keepin it ae homey
