Like Tree5Likes
SC10 4x4 Thread
Old 08-29-2012 | 06:26 PM
  #28981
Wildcat1971's Avatar
These look good and have a warranty unlike the gens ace and turnigy. Gens ace saddles are 25c, dont get them. Turnigy is more like 65c I think, but hobbyking has crazy high shipping.
http://www.promatchracing.com/products.php?cat=38
I have zero issues with my gens ace, but i often wonder if the numbers are accurate. I believe the promatch are tested for mah and c rating
Wildcat1971 is offline
Old 08-29-2012 | 06:28 PM
  #28982
fq06's Avatar
New Nano Tech A Spec's look good, but last I checked they were not in the US warehouse yet... China only.
In the mean time, seen good reviews on Gens ace that are great for the money.
I'll let others comment on the saddle benefits, I run stick. But in general the more centered you can get your weight the better. This car specifically needs added weight in the front and the saddle configuration helps with that as well.
Edit: Looked at the Gens saddle packs after you posted and yeah, 25c is way too low.
fq06 is offline
Old 08-29-2012 | 06:34 PM
  #28983
turnigy makes a shorty pack now? only like $30 too
Old 08-29-2012 | 06:57 PM
  #28984
question. with everyone using a chassis brace on thier trucks has anyone cut out the portion of the rear chassis that goes to the rear transmission ot the chassis ?
just thinking...
twisted is offline
Old 08-29-2012 | 06:59 PM
  #28985
fq06's Avatar
Probably just people running the center stick but they brace it back up with plates of aluminum to get that rigidity back.
fq06 is offline
Old 08-29-2012 | 07:25 PM
  #28986
tom2tone's Avatar
R/C Tech Elite Member
Thanks for the help guys!! What about these.. will they fit?
http://www.amainhobbies.com/product_...hROAR-Approved
http://www.hobbyking.com/hobbyking/s...ehouse%5F.html
The only problem I have with the nano-techs. Is that I have "melted" the negative lead inside the lipo from it getting to hot. The cells still read fine but my truck will cut off after trying to use them. I learned the hard way to be more careful
tom2tone is offline
Old 08-29-2012 | 07:28 PM
  #28987
given those choices I would get the nanotecks. I have heard bad things about the protek. But I would still look at the promatch packs.
Old 08-29-2012 | 07:30 PM
  #28988
are you using bird cages? they are crap. and yeah, I have heard that about nanotechs. I have yet to heard bad things about promatch.
http://www.promatchracing.com/prodde...od=2S520060CSD
Old 08-29-2012 | 07:31 PM
  #28989
one of those saddles was 30c, no good. try for at least 50c
Old 08-29-2012 | 07:33 PM
  #28990
fq06's Avatar
Disclaimer again, I don't run saddles but I know people who use the nano saddles and the pro tec ($80, ouch) was just a hair taller so they should all fit.
Get the 65c nano if you get a nano.
The plug probably got crazy hot from using a bullet for too long letting it get loose in the female port. Then you have arcing and you will melt the plastic case on any lipo.
Unless you were using a low c nano like the green ones or something.
fq06 is offline
Old 08-29-2012 | 08:09 PM
  #28991
JEFFs SC10's Avatar
Wow just came back from running on an indoor track (first time)
track was hard packed dusty- low-med grip a little bumpy.
Just about everything broke on this g'dang thing
receiver acting crazy, had to swap out
center diff teeth worn down had to keep adjusting mesh
rear ballstud popped out-lost all my spacers
had to change to yellow rear springs
reset ride height
tires came unglued-have no idea how, i glued the ish out of em.
I didnt get the truck to work till actual main. kept breaking first two rounds.
I managed to get it together and final round, qualified last, made it to third was right on the leaders and my ballstud in the rear popped out. I got it back together but lost too many laps to make up ground. sucked.
Truck jumps beautifully when I air it out at least lol.
Truck needs a lot of work. In long sweeper rear end would lose traction and come around. so annoying.
Cool thing I was pit right next to Jason Ruona from JConcepts. My truck kept up with his buggy for one lap LOL.
JEFFs SC10 is offline
Old 08-29-2012 | 08:18 PM
  #28992
I am sorry but I laughed a lot. At least a meteor didn't land on your truck.
were you using the 19t front pulley?
Old 08-29-2012 | 08:43 PM
  #28993
tom2tone's Avatar
Thanks again guys... I was using these..
http://www.hobbyking.com/hobbyking/s...po%5FPack.html
Simply I just learned my lesson and I dont mind spending the extra coin to get a well made lipo. If I go with the nano's I just need to be more careful next time
I'll probably pick up the pro match and a set of the nano's.
tom2tone is offline
Old 08-29-2012 | 08:52 PM
  #28994
ok, let us know what you think of them once you run them
Old 08-29-2012 | 08:55 PM
  #28995
JEFFs SC10's Avatar
no I didn't , that's a typical race day for me.
