Like Tree5Likes
SC10 4x4 Thread
Old 10-18-2012 | 12:42 PM
  #30481
Originally Posted by 9turn
Have tried the 8mm m I just trying to understand why I'm traction rolling with it
One thing many people overlook with the 8mm mod is that you should use the shortest camber link settings as well (check BKs settings). The 8mm mod lowers the initial roll center, but the shorter the links are, the quicker the roll center raises as the suspension compresses (roll center is far from static). This combines the initail stability and traction of the 8mm mod with the anti-rollover capabilities many debate it posesses.
Krio is offline
Old 10-18-2012 | 12:58 PM
  #30482
Cain's Avatar
Tech Legend
Originally Posted by Wild Cherry
Cain , confused ?
Ha ! Ha !
Its really easy to make mistakes judging a set-up change ..
You will have to trust me on this one ...
Scotty's Show Down Tour
Have a bunch of team mates in Texas right now , even heard one my best Bro's Greg-Ory is there !
BK is building a new Sc10 for Greg as I post ....
Awesome news for me to hear ....
yeah, it is. But in this case, i didn't. Nor did others who saw the change and commented on what they saw, same thing as i stated. it is what it is.
Cain is offline
Old 10-18-2012 | 01:04 PM
  #30483
Wild Cherry's Avatar
Tech Legend
Cain , sounds you will not be happy till BK tells you bout himself ..
Maybe if you went to Texas ?
or
just trust me ....
Ps , not trying to rub U
Wild Cherry is offline
Old 10-18-2012 | 01:08 PM
  #30484
SOuthernFRIED's Avatar
What's up fellas? I see nothin's changed on the ole thread
SOuthernFRIED is offline
Old 10-18-2012 | 01:33 PM
  #30485
heavyjeffd's Avatar
New FT kit came in yesterday, getting it put together and ready for the RCPro finals.
Not really doing anything special to it except running the Exotek off of my other truck.
Curious how it's going to feel going from stick > saddle.
heavyjeffd is offline
Old 10-18-2012 | 01:54 PM
  #30486
njnewc's Avatar
Gents, I just picked up my first FT SC10 4X4. Any must have upgrades, mods, or just things I need to know. I have read about 1000 pages so far. Thanks for any and all help. Tim
njnewc is offline
Old 10-18-2012 | 02:05 PM
  #30487
WHat kinda track are you runnin on? Indoor? Outdoor? smooth? torn up 1/8th scale style?
There is a big difference in what may be needed between indoor clay and outdoor dirt.
Old 10-18-2012 | 02:08 PM
  #30488
CraigMBA's Avatar
Not a thing, sadly.
CraigMBA is offline
Old 10-18-2012 | 03:25 PM
  #30489
Cain's Avatar
Tech Legend
or
just trust me ....
I would be happy if you get BK to give us a tried, winning setup for 1/8 offroad loose tracks.
Let me know when you have that...
As for the 8mm mod. I tried it based on suggestions from you and others to see what it would do and it performed as I said it did on loose conditions when I used it. It is what it is. Can't do any more than that WC, neither could you
And I don't take it as a rub, some things you say work, some don't unfortunately. I give it all a try, what works I use, what doesn't, I don't. Probably why I use the Center Diff as it does work for what I run on.
Oh, and you may want to speak with your source again on what you saw with the Center Diff, sounds different than what you were lead to believe.
+1
Cain is offline
Old 10-18-2012 | 03:39 PM
  #30490
Tech Legend
Cain
Already gave you a great set-up for your track ....
Told you ditch the 8mm and use standard hub ....
Get off the aftermarket promo gig your on .
Not many that can help you like I can ....
Old 10-18-2012 | 03:47 PM
  #30491
God... You're a Gem.
For the record: I stopped listening to anyone's advice in this thread and just drove my truck. Best thing I ever did. Stop sorting through bad tech (there's alot of it here) and go drive. PM me, Cain, Krio, Or Craig and ask the question. You will recieve TRACK advice and not... Well yeah.
(hope you guys don't mind I placed you)
I really wish we could move on. But it's so hard when that guy makes it as easy as he does.
SC Shaun is offline
Old 10-18-2012 | 04:21 PM
  #30492
njnewc's Avatar
I will be running at Mikes in Dallas, it is a large Clay indoor track. I will be running the Viper Copperhead system with the VX4R.51...
njnewc is offline
Old 10-18-2012 | 04:30 PM
  #30493
That's the info we need! I only ran on loose outdoor tracks, so I'll leave the indoor expert's to advise you on set up and hop up's.
I will tell ya in the year I ran my sc10 4x4 I never broke a single part. Truck is tough as nails!
Old 10-18-2012 | 04:43 PM
  #30494
In the time i've had mind. (release day) I've broke:
2 Servo Savers
2 front bumpers
1 Rear bumper
2 Ball Studs
2 Idler Gears
1 Spring Cup
This is from may 2011 to present day, Racing 3 days a week and trying many options we invented here in the forums (causing excess breakage)
If there is going to be 1 thing, I will never disrespect the chassis for the absolute rock durability.
SC Shaun is offline
Old 10-18-2012 | 06:09 PM
  #30495
That's alot more racing than I did with mine. I bought the Factory Team version the day it came in stock. Raced 1 or 2 times a week through the year. Oh, I did have to replace some diff gears as the early advised shim tolerance was waaaay off. I can't really put that on the truck, more like bad info in the instructions. After I started following this thread and re-shimmed it's been bulletproof.
My 12 year old runs it now and he loves it..
