SC10 4x4 Thread
I've only got 4 pins in the ball diff so I think adding some more is a definite start. I thought it was the other way around for some reason, I can try to play with the M2C blocks a bit too. Both are a quick fix and easy to do. How many more pins do you think I should go up? The track is beyond a high bite track right now, lol!
Thanks.
Thanks.
Me personally I am going to start at 8 for carpet. Definitely though reduce the toe in. Heck, toying with playing with less than stock toe-in on carpet for even more rotation. Seems to be an out of the box option that some of the future competition is coming with.
Thanks.
Thanks.
Like it? Go to 8. Too much? Back off to 7 and see what pin count works for you.
Added pins locks up the diff more like going to a thicker fluid in a gear center diff. Less pins will allow the diff to diff out more and send power to the path of least resistance... the front when on power.
Which ones are you gonna try? 89290 and 89338 are pretty close in size, nothing a few down travel limiters won't cure. We already gotta limit up travel, so the longer bodies might do this on their own...
KEEP US POSTED (if I don't beat you to it....)!
Whut up DOG !@
Maddy , thanks for the reply ...
Already sport-n the rear 16mm Big Bore !
Got um done tonight .
Those are the Ft Ae 16mm off a Ae Sc8
Losi green ft spring
Also using
3mm external &
1m internal limiter
Drove it 1st test tonight as well .
Landings very plush ..........
Laps times good too...
They also look way dialed .....
Drop test surprised both Scotty & me tonight ...
Also using
3mm external &
1m internal limiter
A month ago, I'd have agreed with you, but I put the big bores on my 2wd SC10, and they just feel so damn good. What if the same results come from the 16mms on the 4x4?
WC, they look good with the mounts and everything...are those the rc8 fronts on there? Or rears?
Maddy , their the Ft on the back deal ...
Tomorrow I'll have the ft end done .
will have to refine the set-up a bit more I'm sure .
Way fun project thus far .
I had the same thoughts about this
mod as you had guy, WTG ...
5Likes
