Like Tree5Likes
SC10 4x4 Thread
Old 03-30-2012 | 08:53 AM
  #20371
ilanstylz's Avatar
Originally Posted by Eaglesrx
Is the ft saddle pack mount better than the exotek mount?
I couldn't say since I've never owned the exotek saddle setup. The thing I can say is from seeing pics of the exotek setup is that you have to unscrew the holders on one side each in order to get the lipo's in and out. With the FT version its just a tab you slide in place to hold the strap down. So IMO the FT version is better since its alot easier to get the lipo's in and out.......
ilanstylz is offline
Old 03-30-2012 | 09:01 AM
  #20372
IRM616's Avatar
scales...what is the max weight scales i should get to balance my truck. i dont wanna buy scales that will max out and not work. thanks
IRM616 is offline
Old 03-30-2012 | 09:04 AM
  #20373
ilanstylz's Avatar
I don't know about max but the min. you should go with is 1000g, these are the scales I use:
http://www.ebay.com/itm/1000g-x-0-1g...item27c56b8d23
Old 03-30-2012 | 09:20 AM
  #20374
CraigMBA's Avatar
Those are the scales I have.
You want scales that go from 0-1000. Higher is okay, but they are more money, and they are also larger so they take up room in your pit box (mine go to the track).
CraigMBA is offline
Old 03-30-2012 | 09:27 AM
  #20375
IRM616's Avatar
thanks for the help guys
IRM616 is offline
Old 03-30-2012 | 10:21 AM
  #20376
Cain's Avatar
nice find. I'll see about picking 4 of these up.
By the way, what are you guys using to measure ride height?
Cain is offline
Old 03-30-2012 | 10:41 AM
  #20377
IRM616's Avatar
LOSI MAKES A NICE TOOL.
http://www.ebay.com/sch/i.html?_nkw=...at=0&_from=R40
IRM616 is offline
Old 03-30-2012 | 10:46 AM
  #20378
bajabro's Avatar
Thanks for all the info you guys have put up and the feedback I have received, but I have decided to sell my truck and electronics. Very clean truck with RX8 and pro 4 4000. I will get pics up this afternoon or you can pm me. Thanks again.
bajabro is offline
Old 03-30-2012 | 11:03 AM
  #20379
Cain's Avatar
any opinions on the RPM one? I see they make a metric one.
Cain is offline
Old 03-30-2012 | 11:27 AM
  #20380
Sludge-T's Avatar
I got 4 of these from Harbor Freight and they work great. http://www.harborfreight.com/1000-gr...ale-97920.html
Input your corner weights here http://robrobinette.com/corner_weight_calc.htm
After the saddle setup I had a cross weight of 49.9% (50% optimal) with out any tweaking.
Sludge-T is offline
Old 03-30-2012 | 11:30 AM
  #20381
I use the Associated FT ride height gauge myself.
The RPM one works well too.
rm25x is offline
Old 03-30-2012 | 11:34 AM
  #20382
JayL's Avatar
I much prefer the 4600 over the 4000. The 4000 just has too much torque for any slipper combo
JayL is offline
Old 03-30-2012 | 12:23 PM
  #20383
Vegatron75's Avatar
Got my first, and probably only FT part in the mail today. Here's a couple of pics showing the difference between the stock ackerman bar and the FT one.
BTW, Little local track opened up by me, track has a nice little washboard section, something the bigger indoor track never has.
My truck, running rcshox 2-stage pistons, is owning that section of the track. I can blast it flat out and the truck never gets out of shape, it's a lot of fun. Wish the big track had some washboard sections... If your running on anything other than the smoothest of smooth, do yourself a favor and pick up some 2-stagers.....
Vegatron75 is offline
Old 03-30-2012 | 12:34 PM
  #20384
Cain's Avatar
thanks for the info. May look into the RPM ride height gauge then.
also bought some of those scales. $30 shipped for a set of four out of the USA, I figure not bad.
And it looks like my Pro4 motor is here! Hooray!
Cain is offline
Old 03-30-2012 | 12:40 PM
  #20385
vito's Avatar
will my esc fit in the new pack lay out its a novak gbt2?
vito is offline
