Like Tree5Likes
SC10 4x4 Thread
Old 07-27-2011 | 09:22 PM
  #5371
lcc65's Avatar
Originally Posted by rickfifthscale
can you see how the back of the servo horn will hit the servo case?
Keep going on the installation process. eveything looks good. Mine looks exactly like yours. The knuckles will hit the steering stops before your servo horn hits the servo case. Thats part of the deal with the Associated..really does not travel all that far for as much steering as this truck has!
lcc65 is offline
Old 07-27-2011 | 09:33 PM
  #5372
thats what i was starting to think. thanks
rickfifthscale is offline
Old 07-27-2011 | 09:34 PM
  #5373
Originally Posted by Keeferton
Be careful when smashing down that slipper spring. By just snugging the nut down on the rear top shaft to where the spring was compressed on my truck was enough to bend the top shaft.
I decided to order some new HT pads with the light weight top shaft and MTK clutch basket. The light weight shaft and clutch basket felt as light or lighter than the stock top shaft. The new pads were different material. Much darker color than the ones i had in their before.
After a full day of racing i noticed no fade at all on my slipper and amazing punch out of the corners. Just cave in and get the clutch basket and stop wasting money on pads.
i just wish this car had a center diff instead of this split slipper thing :/ ...
so the clutch basket doesn't weight that much at all? added rotational mass is what's holding me back from getting the basket. i have a more elegant and lighter basket design in mind if the original maker would like to make a version 2.0
(PM me for details)
shadoflame is offline
Old 07-27-2011 | 09:37 PM
  #5374
lcc65's Avatar
(PM me for details)
the basket allows the vehicle to jump off the line as hard as you'd like it to, I know I cant feel any difference between my two trucks..one has it installed, the other does not! The benefits far outway any drawbacks!
lcc65 is offline
Old 07-27-2011 | 11:22 PM
  #5375
CraigMBA's Avatar
Originally Posted by Cameron Kellogg
The stickers are cool but the body stinks. Sorry just my opinion.
Stinks = you think it's ugly? Not to put words in your mouth, I'm sincerely curious whats wrong with it.
CraigMBA is offline
Old 07-27-2011 | 11:45 PM
  #5376
MarqueeRc's Avatar
Whats the hub bub??It looks damn rear the same as the original shell?? They (team Ae) are the most scale looking Short course truck shells on the market , imo..MarqueeRc is just not intrigued b/c they are virtually the same asthetically..
MarqueeRc is offline
Old 07-27-2011 | 11:49 PM
  #5377
Cameron Kellogg's Avatar
Looks like the other two bodies they already have. Nothing special for vent cut outs. I don't know, just no wow factor like the other new bodies that have come out lately by Pro-line and J-concepts.
Cameron Kellogg is offline
Old 07-28-2011 | 12:36 AM
  #5378
racer1812's Avatar
Super Moderator
did this to mine too, No replacement available so mine is currently running a slightly bent top shaft with a clutch basket, no issues but I will replace the top shaft ASAP. Clutch basket is great!!!! I know Mac has had additional orders from my area based on my results....that's ok Mac no thanks needed.......oh racer1812 says..
racer1812 is offline
Old 07-28-2011 | 03:16 AM
  #5379
Originally Posted by turbowop
I disagree. I've been soldering for years with a cheap Craftsman 45w iron. It's all about technique and preparation. A new iron tip needs to be tinned with solder, then tin the posts and wire and all should melt together without issue. I've even used my 45w iron on Turnigy 8awg wires.
That said, those Hakko setups look pretty sweet. But I wouldn't label them as "necessary".
I consider myself experienced and pretty good at soldering... I have soldered two RX8, one with a 45W soldering station and one with a cheap 80W iron. All I can say is that the 80W iron did the job MUCH easier and better.
My experience is that the RX8 is much harder to solder than other things I've done because the heat is dissipating so fast through to the heat sink.
macke is offline
Old 07-28-2011 | 04:50 AM
  #5380
Mac The Knife's Avatar
R/C Tech Elite Member
Mac The Knife say's thank you!!.
Mac The Knife is offline
Old 07-28-2011 | 06:59 AM
  #5381
murky123's Avatar
what is Part #: 91071
front spring kit
you can buy seperate springs for front and rear, but what is the kit? cant find a picture that shows whats in it
murky123 is offline
Old 07-28-2011 | 07:15 AM
  #5382
Yeti AS3's Avatar
front spring kit
The kit includes all the springs available for the front or the rear. Should be 4 springs per kit.
Yeti AS3 is offline
Old 07-28-2011 | 07:24 AM
  #5383
murky123's Avatar
thanks.
just orderd them including the FT blue aluminium wheelhexes
murky123 is offline
Old 07-28-2011 | 07:29 AM
  #5384
GreenSC10's Avatar
Default SC10 4x4 under tray
Thought I would share the new under tray with y'all. I'll be doing the vents this evening with some mesh behind it as well. Wish it would offer some motor cover because where I race it gets dusty....
Attached Thumbnails SC10 4x4 Thread-p1030073.jpg   SC10 4x4 Thread-p1030074.jpg   SC10 4x4 Thread-p1030075.jpg
GreenSC10 is offline
Old 07-28-2011 | 07:32 AM
  #5385
murky123's Avatar
when the motor is also inside the underbody, you would get much more heat trapped
murky123 is offline
