RC10B4.1 FT/WC
Old 02-28-2012 | 10:03 AM
  #12091
brent701's Avatar
Originally Posted by ittjv
Hi Guys,
For those of you running Losi springs; it seems the lowest I can get the front ride height to is 25mm. I have the collars adjusted all the way up and I’m using the traxxas collars over the stock threaded collars and Losi spring cups. Am I doing something wrong or is this par for the course?
Thanks,
Jose
Did you order the correct springs?
brent701 is offline
Old 02-28-2012 | 10:04 AM
  #12092
brent701's Avatar
Originally Posted by Bob Barry
surgical team.
to remove Brent's foot from your ass
Originally Posted by nismomike
Brent just text me and said all i needed to convert was a B4.1 W.E. , losi spring cups, traxxas spring retainers, and a cucumber. I'm just not sure about one thing and that is, what are the traxxas spring retainers for? He said the cucumber has something to do with anti-squat lol.
brent701 is offline
  #12093
Hi Guys,
Thanks,
Jose
I use the Lunsford titanium shock mounts-
http://www.amainhobbies.com/product_...Shock-Mounts-4
Put 2 washers so the shock itself extends away from the shock tower, problem solved no robbing, ride heigh at 24mm.
GuiltyByAssoc is offline
Old 02-28-2012 | 10:08 AM
  #12094
F18engineguy's Avatar
Default Kyosho Big Bore - Gold
Does anyone know where I can get a set of these? I have looked everywhere and they are sold out. Thanks
I'll even take a used set if someone has them
F18engineguy is offline
Old 02-28-2012 | 10:20 AM
  #12095
Asharus's Avatar
twisted rc had a few on hand last week when i ordered them, but i just checked and it looks like they're on back order now
it was the only place that had them during my search
edit: i saw a set on ebay i think.
Asharus is offline
Old 02-28-2012 | 10:24 AM
  #12096
you freaks running KY springs... did you decide on the best combo yet? I MIGHT buy one pair front and rear, if I get really bored one night and they pop up avail Amain hahaha.
Bob Barry is offline
Old 02-28-2012 | 10:28 AM
  #12097
Originally Posted by jamr1130
I know you say boosted but I run 17.5nt at WCRC and gear it at 72/33 and it's plenty fast.
cool, i appreciate it man thanks!
D
derbrylac is offline
Old 02-28-2012 | 10:29 AM
  #12098
rosko's Avatar
I just got the hex conversion where do the c/e clips go that comes with the axles
rosko is offline
Old 02-28-2012 | 10:32 AM
  #12099
Wild Cherry's Avatar
Rosko
install clip in-between bearings
Wild Cherry is offline
Old 02-28-2012 | 10:33 AM
  #12100
ehhh i'm rusty on this one but I believe it's in between the bearings would be. Replaces a crush tube.
  #12101
davidfast's Avatar
On the little notch on the axle, that then lines up in the carrier only 1 way.
The notch in the middle. So it goes Bearing, C-Clip Bearing http://www.teamassociated.com/pictur...9881.ps_md.jpg
davidfast is offline
Old 02-28-2012 | 10:35 AM
  #12102
I think so - TLR5173 (Org) and TLR5174 (Slvr) for the front.
I haven't added any weight yet, so that might help.
ittjv is offline
Old 02-28-2012 | 10:39 AM
  #12103
nismomike's Avatar
What lipo are you using when you check your ride height?
nismomike is offline
Old 02-28-2012 | 10:44 AM
  #12104
rosko's Avatar
Thanks everyone for your help
rosko is offline
Old 02-28-2012 | 10:58 AM
  #12105
makaluch's Avatar
What position are you guys using for the hub carrier on the front arms of a +8 WC?
Mine only came with the big single spacer per side so my only sensible option was moving the carrier forward. I'll grab more spacers if the center position is standard. I can't find any clear information on carrier placement or it's use as a tuning option.
makaluch is offline
