SC10 Thread
Old 02-17-2012 | 07:29 AM
  #9931
J_Bone's Avatar
Wow....this is getting out of hand.
J_Bone is offline
Old 02-17-2012 | 07:35 AM
  #9932
uWtech14's Avatar
How bout some good ol vaseline? My buddy in highschool use to swear by it. Now I know why.
uWtech14 is offline
Old 02-17-2012 | 09:15 AM
  #9933
Originally Posted by rednck21
any one tried the Losi 22T front springs on the front of their SC10 yet? the 22 fronts will work, but a spring thats slightly longer than the 22 front would be nice...
GHEA Collars, Green 22T front, Yellow rear on my setup.
sbales is offline
Old 02-17-2012 | 09:41 AM
  #9934
Mizchief's Avatar
Originally Posted by kc_nitro_rc
Okay here's a speed secret none of you know: KY brand jelly. You won't find anything better. It takes the heat, resists moisture, lasts a long time, and best of all gives you the most pleasure.
I like this stuff: http://www.techtpaintball.com/Products.aspx?CAT=3318
I bought it a while ago for my paintball gun so i started using it on my rc as well.
It's a very thin grease, but stays in place pretty well.
Isn't KY petroleum based (I know Vaseline is)? Probably not too big a problem in the tranny, but oil based lubes can eat away at your o-rings.
Mizchief is offline
Old 02-17-2012 | 10:21 AM
  #9935
CraigMBA's Avatar
It's water based.
CraigMBA is offline
Old 02-17-2012 | 10:24 AM
  #9936
CraigMBA's Avatar
You can use the 22 rears with the GEHA collars.
CraigMBA is offline
Old 02-17-2012 | 10:26 AM
  #9937
bzb
Originally Posted by Lake Ober
Wow, this is getting reallyyyy wierd
But then again, that's why I like this message board over all other SC10 one's. We go from talking about diff's to anal lube in a matter of just a few posts. I'd hate to see where we go from "anal lube"
is this also a topic about tranny's?
bzb is offline
Old 02-17-2012 | 10:32 AM
  #9938
That's just wrong!!!
mark in wi is offline
Old 02-17-2012 | 01:43 PM
  #9939
Oztiger's Avatar
Thumbs up SC10 Issue
Thanks to those that replied re the dogbones issue. two 'o' Rings in the outdrive and two in the hub have fixed the problem. CVD's on order.
Its funny because I thought the dogbone was sitting way too far out for 2 'o' rings to fix the problem lol. (used to working on 1/8 buggies)
cheers.
Oztiger is offline
Old 02-17-2012 | 03:17 PM
  #9940
Mizchief's Avatar
cheers.
Yea when I tried that I didn't have any spares, so I just did two on the out's and none in the hubs and it was only a problem on high-grip fast and sharp turns.
Anyone have this issue with the stock arms installed? I wonder if it's just that the RPM's are longer, which I guess would be a good thing.
Mizchief is offline
Old 02-17-2012 | 05:03 PM
  #9941
Cain's Avatar
nevermind, I think I see the problem.
Cain is offline
Old 02-18-2012 | 06:59 AM
  #9942
Yes
sbales is offline
Old 02-18-2012 | 07:04 AM
  #9943
Mizchief's Avatar
I haven't been driving the 17.5 for long. Is it normal to have crappy breaking with that motor? I know rear wheel breaking sucks anyway (compared to a 4x4) but I can't get my wheels to lock down until almost at a stop.
I wish someone would figure out how to to run front disc brakes on a 1/10 scale truck! I've seen it done on the VMX dirt bike. basically just like your standard cable break.
Mizchief is offline
Old 02-18-2012 | 07:15 AM
  #9944
Smoked an idler gear the other night, what the deuce!?!?! Happened right after my son broke the front end of his 10RS trying to clear the new front straight triple, which is more like a quad....... I was just doubling onto the deck and jumping into the turn, he had it in his mind to clear the whole thing. He saw the 8.5 buggies doing it and figured he could too.
vw addict is offline
Old 02-18-2012 | 07:16 AM
  #9945
njnewc's Avatar
Mizchief what esc r u using. I run a viper vtx10 and have great brakes. Check ur brake strength.
njnewc is offline
