SC10 Thread
Old 02-17-2012 | 12:36 AM
  #9916
Suspended
Originally Posted by Ryno B4.1
Another way to make your diff a bit smoother and much more quiet is to apply a little 70-80 wt shock oil between the idler and diff gear
Shock oil is not supposed to be used as a lubricant for the transmission. I love this new trend of using shock oil or Pledge for transmission lube. Pledge is 10% parafin wax, 10% silicone, 60% WATER and the rest is Isobutane and Propane. USE A FREAKING GREASE TO LUBRICATE THE GEARS. JUST BECAUSE IT MAKES THE TRANSMISSION QUIET, DOESN'T MEAN IT'S RIGHT. I run Boca Bearing, Lightning Lube in all of my cars transmissions and it works great. All of my cars are whisper quiet, and the gears last a really long time.
h8thatadmin is offline
Old 02-17-2012 | 02:31 AM
  #9917
Oztiger's Avatar
Default SC10RS issue
Hi learned friends. I have returned to my roots, 1/10 Electric Off-road.
I have purchased a SC10RS. Fitted a few options and stumbles upon a problem.
I fitted RPM Arms to the rear, Ball Diff (Associated) and non associated rear hub carriers. Now I matched all components up and they all appeared to be the same shape/size etc. So now a few questions.
Why do the dog Bones fall out of the hubs now?
Is there a need to fit longer CVD's to the truck to stop this?
If so what is the part number?
Anything else I should know?
Must say Associated have let me down with this truck. Both metric and Imperial fastners?? (WHAT THE?)
[IMG][/IMG]
Oztiger is offline
Old 02-17-2012 | 02:48 AM
  #9918
Registered User
Sorry Mr. Know it All. You must only be on here to tell people what they are doing wrong since I'm sure there is nothing you could learn from a bunch of idiots like us. I happen to like the shock oil that I use and NEVER SAID ANYTHING ABOUT PLEDGE so go find someone else to yell at. We don't need this crap from you
Ryno B4.1 is offline
Old 02-17-2012 | 03:37 AM
  #9919
idrummerboy13's Avatar
pledge is what a.e drivers do, or silicone diff lube...thanks for the heads up
idrummerboy13 is offline
Old 02-17-2012 | 04:29 AM
  #9920
kc_nitro_rc's Avatar
No need for the magic snake oils when the parts are fresh. Maybe when they are worn. Those team drivers don't know how to build a car. There daddy does that ;-)
kc_nitro_rc is offline
Old 02-17-2012 | 04:45 AM
  #9921
Mizchief's Avatar
Originally Posted by JEFFs SC10
Is anyone.running the avid rack?
I've raced with it once and it felt pretty good. I didn't notice a huge difference personally, but I've only raced the truck one other time. I got it mostly to remove some of the slop and did notice it help the truck track a little straighter on bumpy gravel.
Mizchief is offline
Old 02-17-2012 | 04:50 AM
  #9922
Mizchief's Avatar
[IMG][/IMG]
My bones started popping out too, but I did RPM's from the start so didn't no they could have been the cause. Maybe they are a tiny bit longer.
I think the best thing to do is just upgrade to the CVA's, but if you want to save the cash you can try adding two o-rings inside the outdrive so that the bone can slide as far. I did that as a quick fix and it got me by till I got the CVA's
Mizchief is offline
Old 02-17-2012 | 05:14 AM
  #9923
CoyoteSlash's Avatar
There was probably a reason your account got messed up.
It's common knowledge, 50-70wt makes a good Tranny silencer, Get over it and use your crap.
CoyoteSlash is offline
Old 02-17-2012 | 06:08 AM
  #9924
Okay here's a speed secret none of you know: KY brand jelly. You won't find anything better. It takes the heat, resists moisture, lasts a long time, and best of all gives you the most pleasure.
Old 02-17-2012 | 06:25 AM
  #9925
20 SMOKE's Avatar
[IMG][/IMG]
if you are using dog bones you need to put 2 old orings in the hub side and 2 on the diff side,i have bones in mine and they never come out
20 SMOKE is offline
Old 02-17-2012 | 06:31 AM
  #9926
Stealthpilot's Avatar
Better yet, use the KY brand his and hers! Put the his stuff on the idler and the her stuff on the diff gear! If you switch it up, your on your own, just saying.
Stealthpilot is offline
Old 02-17-2012 | 06:38 AM
  #9927
elex300's Avatar
+1 on his and hers Works good for building shocks too. You can figure out the rest.
elex300 is offline
Old 02-17-2012 | 07:09 AM
  #9928
J_Bone's Avatar
+1 My son always forgets to put that o-ring in.
I don't recall any metric on my truck except for the motor screws? Am I missing some?
J_Bone is offline
Old 02-17-2012 | 07:15 AM
  #9929
CraigMBA's Avatar
CraigMBA is offline
Old 02-17-2012 | 07:22 AM
  #9930
Lake Ober's Avatar
Wow, this is getting reallyyyy wierd
But then again, that's why I like this message board over all other SC10 one's. We go from talking about diff's to anal lube in a matter of just a few posts. I'd hate to see where we go from "anal lube"
Lake Ober is offline
