SC10 Thread
#9901
Question about shimming the ball diff. Do you shim it so there is 0 side to side play when it's installed in the case as long as it spins free or do you want a little bit of play from side to side? Also will it hurt to put a shim in one side but not the other if one does the trick? Thanks
#9902
I would want a teensy weensy bit of play....like 0.2mm. Shimming one side? Hey, if it works why not?
#9903
How often do you guys change the gears inside your diff? Put a fresh diff in my SC10 and it started making noise when I squeeze the throttle (on power) kind of like when your pinion & spur gear mesh is to tight. It's not the honking noise from a slipping diff. That is what has me puzzled. Slipper is set to pull the front up about 1-2".
#9904
#9905
#9906
Forgot to mention that I'm using the ball diff. There are no shims. Just the spacer on the top shaft. My 6.5 must have worn things out. Guess I'll go grab a new top shaft, idler, & the gear the diff balls sit in.
#9914
I just picked up a SC10 in hopes for some racing action. I still have a slash 4x4 and previously had a Slash 2WD that I did the 32P mod on and loved it. Now I have a ton of 32P pinions and wanted to know if I could do a similar mod to the SC10?
#9915
