SC10 Thread
Old 02-21-2012 | 07:08 PM
  #10066
Originally Posted by CoyoteSlash
anyone have any preliminary suggestions on a Grinding in the Tranny>Slipper Setup? When I take off the cover it doesn't echo as bad but it sounds like something's grinding up against something every rotation.
- It did this with the Ball Diff and the Gear Diff
- And with the old Tranny case, and the new Tranny Case.
- Checked Spur and Pinion, perfect, pads, plates, fine.
- The only thing I see is the Topshaft is wobbling a bit. But it goes into the tranny smoothly.
- All bearings are solid and free spinning.
It's odd to me. It drives great, It's not causing any drag either. Only an extremely obnoxious "broke" noise.
check to make sure the long transmission screws arent hitting the back of the slipper plate.
Pimpin is offline
Old 02-21-2012 | 08:24 PM
  #10067
BCbud's Avatar
Default Gearing for my first off road race ever.
Good day!
I just bought an sc10 2wd last sunday and have been busy fixing all the things wrong with it. I am going to a my first off road race this weekend and would like some help with gearing. The motor is a castle 4600 4 polel and the speedo is a mamba max pro and it has a ball diff. The spur is an 81 tooth. The track was started to be put down today so the surface is anyones guess. Here is the layout of the track.
http://www.rctech.net/forum/10360644-post109.html
Thanks, Neil.
BCbud is offline
Old 02-22-2012 | 12:32 AM
  #10068
CoyoteSlash's Avatar
Originally Posted by njnewc
Can you take a quick video so we can hear the noise. Check the motor plate screws, if one is too long it could rub the slipper...
Transmission Screws are floppy loose, and the noise remains. Not the motor either.
Video:
http://imageshack.us/clip/my-videos/7/hv7.mp4/
CoyoteSlash is offline
Old 02-22-2012 | 04:03 AM
  #10069
Video:
Actually sounds cool,like a revving engine.
Don't really have a clue what it can be
TeKiNxRampage is offline
Old 02-22-2012 | 04:20 AM
  #10070
J_Bone's Avatar
Exclamation
Video:
I couldn't see the video on my phone but make sure the inside slipper plate isnt rubbing the motor plate.
J_Bone is offline
Old 02-22-2012 | 04:24 AM
  #10071
Nope.
It's not a metal screech grind. You'd have to listen. it's plastic tap at high speed is the best I can describe it.
Old 02-22-2012 | 04:32 AM
  #10072
B.A. Racer's Avatar
Nope.
check you diff and make sure you not missing something..it also sounds like a spun rotor on your motor...check your motor
B.A. Racer is offline
Old 02-22-2012 | 04:46 AM
  #10073
I said in my original question, that the ball diff and my brandnew gear diff both were present during this noise.
the motor spins great, no sound.
Old 02-22-2012 | 04:48 AM
  #10074
bds81175's Avatar
Moderator
It may sound great under load but it may cut loose with the pinion connected to the spur. Its a pretty horrific sound when I have heard it. Have you tried a different motor yet?
bds81175 is offline
Old 02-22-2012 | 04:53 AM
  #10075
The load being 3 gears and no tires on a bench?
Old 02-22-2012 | 05:00 AM
  #10076
bds81175's Avatar
Moderator
Its a huge load compared to just a pinion. Re-reading your post, if you have a bent top shaft it will make quite a racket too. We're throwing out suggestions here. Don't knock 'em til you've tried 'em.
bds81175 is offline
Old 02-22-2012 | 06:10 AM
  #10077
gamedog1966's Avatar
Originally Posted by Ryno B4.1
Well your safe. A real addict would be in the car driving 4 hours to find another track. A true addict will get their drug at any cost
Hahahaha well when my track is down, my nearest is 40 min away and I'm down for the git down so 40 min later I'm running laps lol lol
gamedog1966 is offline
Old 02-22-2012 | 06:48 AM
  #10078
CHIZZLE's Avatar
Video:
How tight is your gear mesh?
CHIZZLE is offline
Old 02-22-2012 | 07:59 AM
  #10079
brent701's Avatar
I am 80% sure it is the Mesh from the top shaft to the idler.
I have this same noise in my B4.1 tranny after I replaced the Idler and top shaft along with new Avid bearings. also tested with old bearings.
Even installed old parts back in noise gone. new parts noise back.
Not sure 100% what it is with the gears but I am pretty sure its the idler to top shaft gear mesh.
I also tested it with 2 different ball diffs and 2 different gear diff's same noise
brent701 is offline
Old 02-22-2012 | 08:39 AM
  #10080
AErckidd's Avatar
I bought a Factory Team SC10 and it came with plastic rear hubs, was it supposed to come with aluminum? I thought it was just like the B4.1
AErckidd is offline
