Like Tree5Likes
SC10 4x4 Thread
Old 02-11-2012 | 08:17 AM
  #17251
lip
Anyone know the cheapest place to buy the exotek chassis?
I remember someone mentioning it with a link for about $90 but I cannot find it now...I've searched this forum...
Thanks.
lip is offline
Old 02-11-2012 | 08:24 AM
  #17252
Farmer_John's Avatar
Originally Posted by boborc
If you want to run 1/8 scale than buy one all this is going to do is divide the class,hence how the truggy developed killed moster truck,took a hit on the buggy and then since every talent lacking A-hole could drive one of these beasts it became a hack fest. Which every descent drive gets sick and tired of so the class dies. Here we go again. Let 1/10 be 1/10 and 1/8 be 1/8 thats why they are different.
I don't think it'll divide it, as this grows, the class will define itself better.
It's all Traxxas' fault. Too bad they missed the mark on performance, because they defined the 8th scale size for their "10th scale" truck.
Farmer_John is offline
Old 02-11-2012 | 09:39 AM
  #17253
MantisWorx's Avatar
I agree 100% but unfortunately it is evolving away from what it was originally intended And that puts the SC10 at a disadvantage, unless we can figure this out! its not over yet, i am not throwing in the towel
MantisWorx is offline
Old 02-11-2012 | 09:49 AM
  #17254
CraigMBA's Avatar
When does the Caster SC truck drop anyway?
CraigMBA is offline
Old 02-11-2012 | 09:53 AM
  #17255
Wild Cherry's Avatar
I have lots 1/10th gas truck experience on 1/8th scale layouts ..
Only way a 1/10th car is gona perform the way it was intended on those tracks is if they redesign the layout for a 1/10th scale ride..
It won't happen, the 1/8th guys would never allow a 1/10th to go as fast as their precious 1/8th buggy on there layouts ....
Reality is a bitch
Wild Cherry is offline
Old 02-11-2012 | 10:07 AM
  #17256
Thanks.
http://www.trick-parts.com/product_p/1162.htm
Krio is offline
Old 02-11-2012 | 10:08 AM
  #17257
Reality is a bitch
That's why I run Ebuggy...
Old 02-11-2012 | 10:16 AM
  #17258
You know It farm , better to have a big ride for big tracks ....
Old 02-11-2012 | 11:04 AM
  #17259
OSherman's Avatar
Questions??
im curious to know what everyone thinks about the 'Factory Team' tire setup.. Suburb Rears, Holeshot Fronts.
beginner setup, or race proven?
im going to try it only because when i bought my HoleShots i didnt realize there was a '2.0' version of all these tires (i bought 1.0).. So im getting a set of '2.0' Suburbs and will play matchmaker to see what happens.. any predictions?
OSherman is offline
Old 02-11-2012 | 11:19 AM
  #17260
Default Rumble @ the Rocky's
1st round qualifying complete , Scott Brown Tq's the Sc 4x4 class.....
Check out the Rumble going on today @ www.liverc.com
Old 02-11-2012 | 11:43 AM
  #17261
Cain's Avatar
0 bump steer washers
inside on rear tower for shock position
used a Multiplate slipper , not sure if they were using a pin or what ever so i left it blank...
Ty for the help
no prob. I'll give the setup a try. do you recommend any changes to it for carpet?
+1, get the membership too before ordering.
Cain is offline
Old 02-11-2012 | 11:48 AM
  #17262
no experience running the truck on carpet , but I have plenty of experience with slicks & high traction surfaces...
As a rule never change set-up much for slicks or higher traction .
Just adjust the ride height 1m to 2 m lower (22.5m <> 23.5 m ) that is all ...
Old 02-11-2012 | 12:20 PM
  #17263
blakelenk521's Avatar
I am going to run that setup tomorrow night with another guy. I ran calibers up front and suburbs in the rear and it was a very nice improvement. I'm excited to see how the holeshots work since they are more of a "race" tire.
blakelenk521 is offline
Old 02-11-2012 | 12:35 PM
  #17264
My prefered clay track tires:
JC double D greens front
HB Beams Pink rear
DDs didn't have enough side bite for the rear, Beams had too much for the front. mixing gave me balance.
Still running the same 8 tires I glued up last May.
Old 02-11-2012 | 01:22 PM
  #17265
Scott also Tq the 2nd round of Sc4x4 !!!!
Even improve his time a bit from the 1st round ....
Scott's Sc10 4x4 is looking good .....
