SC10 4x4 Thread
If you want to run 1/8 scale than buy one all this is going to do is divide the class,hence how the truggy developed killed moster truck,took a hit on the buggy and then since every talent lacking A-hole could drive one of these beasts it became a hack fest. Which every descent drive gets sick and tired of so the class dies. Here we go again. Let 1/10 be 1/10 and 1/8 be 1/8 thats why they are different.
It's all Traxxas' fault. Too bad they missed the mark on performance, because they defined the 8th scale size for their "10th scale" truck.
I agree 100% but unfortunately it is evolving away from what it was originally intended
And that puts the SC10 at a disadvantage, unless we can figure this out! its not over yet, i am not throwing in the towel
I have lots 1/10th gas truck experience on 1/8th scale layouts ..
Only way a 1/10th car is gona perform the way it was intended on those tracks is if they redesign the layout for a 1/10th scale ride..
It won't happen, the 1/8th guys would never allow a 1/10th to go as fast as their precious 1/8th buggy on there layouts ....
Reality is a bitch
Reality is a bitch
Reality is a bitch
Reality is a bitch
im curious to know what everyone thinks about the 'Factory Team' tire setup.. Suburb Rears, Holeshot Fronts.
beginner setup, or race proven?
im going to try it only because when i bought my HoleShots i didnt realize there was a '2.0' version of all these tires (i bought 1.0).. So im getting a set of '2.0' Suburbs and will play matchmaker to see what happens.. any predictions?
1st round qualifying complete , Scott Brown Tq's the Sc 4x4 class.....
Check out the Rumble going on today @ www.liverc.com
As a rule never change set-up much for slicks or higher traction .
Just adjust the ride height 1m to 2 m lower (22.5m <> 23.5 m ) that is all ...
JC double D greens front
HB Beams Pink rear
DDs didn't have enough side bite for the rear, Beams had too much for the front. mixing gave me balance.
Still running the same 8 tires I glued up last May.
5Likes
