RC10B4.1 FT/WC
"Originally Posted by lip
Is the B4 coming with metric screws? What about B4.1?
Also, what are the bearing differences(part of cars...not exact bearing numbers)?
Thanks. "
imperial
Are both cars imperial? I thought the B4.1 was metric...
Thanks. "
imperial
Most AE drivers were running Kyosho, Losi, or testing other BB springs, and some are still running stock AE springs. I did not see any BB shocks on any AE cars. Check out Ty Tessmann's B4
https://www.facebook.com/media/set/?...1&l=fb38cf1713..
I have some rear wheels from a Kyosho I had that have the 12mm Hex. I want to be able to use them on my FT B4.1. I went to my LHS today and they sold me the Pro-Line 12mm hex.
I just noticed though that they are the "front" PRO6076-00 ones.
Will these still work on the rear ? Whats the difference?
Okay thanks! I am actually looking for a just a little more entrance traction so maybe I'll try adding to the rear.
Only other question, would the same info be true, if I don't brake through turns? I actually don't use my brake at all except for controlling the pitch of the car in the air, I just get off throttle or get on, because I have found my car will spin out if I apply brake. I've turned it down via esc, but then I can't pitch my car forward in the air too well.
No, I have the drag brake set pretty low on my tekin rs, set at I think 8, out of 100. My steering is fine, almost too much. What I am looking for is just a litttttttle more rear end traction, but not too much where I get traction roll issues. I just don't know what else to change to get that tad bit more rear end traction on corner entry. I am willing to lose just a little bit of steering for it, but prefer not. If not im out of ideas, the car is driveable, but I am also about to go from a 10.5t to an 8.5t so I don't know what handling issues I'll see then.
Think of it this way, if you limit down travel you also limit the distance that the chassis can move up under accel/decel. So if you increase the number of limiters in the front shocks you don't allow the front of the car to rise up as much under acceleration. This will give you more exit steering at the possible expense of exit rear traction. If you add limiters to the rear shocks you are limiting the distance that the back of the chassis can rise up under braking. This should give you more corner entrance rear traction and less entrance steering. Make sense?
