Like Tree5Likes
SC10 4x4 Thread
Old 01-28-2012 | 09:50 AM
  #16006
Using the YeahRacing fan to cool the motor would help the stock slipper pads too? Isn't the heat that mess the stock pads up coming from the motor?
coconut is offline
Old 01-28-2012 | 09:53 AM
  #16007
hELllNino's Avatar
Originally Posted by jsamarin
does anyone know where you could buy a somewhat thin sheet of lead. Im wanting to cut a piece and mount in under my saddles to get some weight as low as possible. I think someone on here has done this a while back, but i cant remember who it was. Any feedback would be great
http://www.golfsmith.com/product/300...-lead-tape-1-2
this is what i used on my chassis and also what i use to balance wheels. YOU WILL NOT GET THE SAME EFFECT AS EXOTEK. i tried it, trust me. even with the chassis brace, is not the same. it definitely does help though. i tried it lining the entire center section of chassis, then just the front half. it was better with the front half (i did not have saddle conversion though, would have been even better)
you still have all the flex of regular chassis though, and when you increase weight, i think you need to remove flex to keep the truck controllable. with the flex gone, it makes the truck sluggish at slower speeds, but better for more aggressive driving at faster speeds. it is the lateral flex that needs to stiffen up, not just longitudinal as the brace fixes
just make sure your battery still fits alright, it is not that thick, but made it a tight fit with the revtech 6500 (slightly thicker battery case)
hELllNino is offline
  #16008
Mizchief's Avatar
Originally Posted by jnyrcr
Pro golf shops sell rolls of thin lead for golf clubs, that might work.
Dynamat may work as well. Not quite as heavy as lead though.
Mizchief is offline
Old 01-28-2012 | 09:54 AM
  #16009
Originally Posted by riverdog
Posted this a few days ago with little response:
MMP and pro4 4600- should I run the MMP in full sensored mode of smartsense?
Thanks,
smartsense, you may want to run an external bec as well, that's what I run.
jnyrcr is offline
Old 01-28-2012 | 09:57 AM
  #16010
Mizchief's Avatar
Originally Posted by johnbugman
I bought 4 food scales from walmart for 5 bucks a piece
You can get them on amazon as well. Would get 1000g capacity each.
Mizchief is offline
Old 01-28-2012 | 10:39 AM
  #16011
boborc's Avatar
Do these kevlar belts I'am hearing about make a big difference and where do I get one. Never had a R/C with a belt before.
boborc is offline
Old 01-28-2012 | 11:56 AM
  #16012
Mac The Knife's Avatar
No, that heat is generated by the pads themselves. People have used a temp gun on the slipper and discovered it was way hotter then their motor.
Mac The Knife is online now
Old 01-28-2012 | 11:58 AM
  #16013
Sorry ,
if your slipper grazed & heated up like you just described?
You must of set it way to loose ...
And that would never happen in a perfect world,,,
Old 01-28-2012 | 12:07 PM
  #16014
Wild Cherry's Avatar
nobody is perfect....
never melted down a spur yet though ...
Wild Cherry is offline
Old 01-28-2012 | 12:08 PM
  #16015
got the name or link ?
Old 01-28-2012 | 01:47 PM
  #16016
Misfit138's Avatar
i'm running 15/62 with my 4000kv, and for swaybars, you deffinatly want to run yellow in the front, and either blue or orange on the back. running the yellow on the front calms the steering down (which the truck needs)and helps with traction rolling and running a softer bar in the back gives you more on power grip in the rear end coming out of corners.
You are correct sir. Yellow in the front blue in the rear. I had it backwards in my post.
Misfit138 is offline
Old 01-28-2012 | 02:19 PM
  #16017
CoyoteSlash's Avatar
Sorry ,
Hey Broseph'.
Remember the part where people couldn't tighten it "enough" to not have the plates just spin with no acceleration at all?
Or is that another user error from 75% of the Sc10 4x4 population like the A-arm?
Chassis braces are out. I'm going to start slimming down on parts due to the possibility of the FT Sc10 sometime in the first quarter. I won't be needed then.
Urge... to drive... overwhelming other obligations...
CoyoteSlash is offline
Old 01-28-2012 | 02:51 PM
  #16018
Thomas P's Avatar
The Clutch basket from MTN...is the or one of the finest invesment...to be hounest, i had never enver any prob with my s tcok sliper,..but i bought one anyday...
used a Dynomax/Advance 5.5TQuint series...i had not so god hope on this 540ísh motor...but after sick race temopo on carpet with ultra grip i landed on 90-95 on 15/93...the ca had a REAL goos speed..and this was after 10 min in race tempo...and the car felt sick nice vs Castle 550 / 2400 550 motor...
i will stay with this setup as long as i can..
any Q ask
Thomas P is offline
Old 01-28-2012 | 02:54 PM
  #16019
tom2tone's Avatar
For those running turnigy lipos, which 2s fit well? Is anyone using the foams to move the location of the batt?
tom2tone is offline
Old 01-28-2012 | 02:55 PM
  #16020
boborc's Avatar
No that is what I'am looking for. There is one on ebay but comes from korea I believe
boborc is offline
