Like Tree5Likes
SC10 4x4 Thread
Old 01-09-2012 | 01:22 PM
  #14506
Resqnu's Avatar
Default pinion and gear for Tekin pro4 4000
What pinion and gear do you recommend for the Tekin pro4 4000? I am going to buy 3 pinions and need the gear you guys like.
Resqnu is offline
Old 01-09-2012 | 01:36 PM
  #14507
Steve737's Avatar
60 tooth spur. 13, 14, and 15 tooth pinion. I run on a small indoor track and use the 15 with no problems.
Steve737 is offline
Old 01-09-2012 | 01:46 PM
  #14508
LouDawg's Avatar
Im running 62/14 with my pro4 4000kv in small/medium indoor clay track. I hit 160s after a 6min main
13, 14, 15 is a great start
LouDawg is offline
Old 01-09-2012 | 01:50 PM
  #14509
vito's Avatar
Originally Posted by tom2tone
Ok I'm going to go ahead and order the clutch basket and garodisc. I put them together? Is the clutch basket difficult to assemble? Order from here right?
http://gearrings.weebly.com/rc-racing-stuff.html
Then the garodisc..
http://rcshox.com/shoxshop/catalog/p...c4af386b5bedca
can i use my visa card with pay pal on them sites for some parts. thank you
vito is offline
Old 01-09-2012 | 01:56 PM
  #14510
Resqnu's Avatar
Thanks, my kit came with a 62T and 93T. I will get the 13,14,15 pinions for the 62T.
Can someone explain why the 62T is preferred as the manual says 62T is for 550 motors and 93T is for 540 motors?
Resqnu is offline
Old 01-09-2012 | 02:04 PM
  #14511
murky123's Avatar
[QUOTE=buckeyeboy30;10145705]
Originally Posted by murky123
and when you do it this way, you will still be able to use the AE underbody / overtray
Is this right?
[IMG][/IMG]
perfect
murky123 is offline
Old 01-09-2012 | 02:06 PM
  #14512
I want to know how the Reedy Sonic 550 is.
you hear so little about this motor. why?
I think that the AE Team are running the Reedy motors, not the shorter 4 Poles, at least they were the last time I looked at their setup sheets. I know that the LRP SXX V.2 seems to be the choice of ESC for one of them, though.
Don
Keyrigger is offline
Old 01-09-2012 | 02:15 PM
  #14513
Nyk
Originally Posted by Wild Cherry
Pacific N/w Shoot Out layout is easy , no big jumps or whatever ..
But ....
Its real hard to go fast on & be consistent , demands the best skills you have ...
What kind of slipper set up?
Nyk is offline
Old 01-09-2012 | 02:20 PM
  #14514
Misfit138's Avatar
Originally Posted by nickfin91
no, i think im going to try the turnigy nano tech 65-130c ones from hobby king
I bought all the parts to convert it to saddles, now i just need saddles
I'm doing the same. I just ordered those batteries today.
Misfit138 is offline
Old 01-09-2012 | 02:28 PM
  #14515
Chad Smith's Avatar
Yes that is what PayPal is. You use your mastercard,visa card etc to buy things.
Chad Smith is offline
Old 01-09-2012 | 02:29 PM
  #14516
Chad Smith's Avatar
Let me know how those saddles work. I might have to pick some up.
Old 01-09-2012 | 02:43 PM
  #14517
Chad Smith's Avatar
Is this right?
[IMG][/IMG]
Yes but to make sure do you have a locknut on the other end of the screw?
Old 01-09-2012 | 03:56 PM
  #14518
vito's Avatar
ok i found my motor a cc 3800 4 pole and where to start out with gearing?
vito is offline
Old 01-09-2012 | 04:07 PM
  #14519
SCTDan's Avatar
The 62 is 32 pitch and holds up better under heavy power.
SCTDan is offline
Old 01-09-2012 | 04:30 PM
  #14520
Mizchief's Avatar
I got my dual stage pistons and center diff in today!
I think I'm going to try 10k in the front diff, 5 in the rear, then 30wt in the front shocks, but then my next size oil is 25. Is 25 too light for the rear? I was thinking about mixing up some 27 using 20 and 35 (since I don't have much 30 left)
The races I care about are on 1/8 scale hard pack clay mostly smooth with a little dust on top depending on how late it is in the evening. However I also do some indoor carpet racing, mostly just screwing around.
Mizchief is offline
