Like Tree5Likes
SC10 4x4 Thread
Old 01-22-2012 | 11:13 PM
  #15571
Wild Cherry's Avatar
dup
Wild Cherry is offline
Old 01-22-2012 | 11:14 PM
  #15572
IRM
I have no friends, ask cameron
Coyote & Cameron live in Oregum
i live in Tacoma , armpit of Washington state....
Coyote , Great news , glad to hear you will be attending..
Old 01-22-2012 | 11:19 PM
  #15573
IRM616's Avatar
IRM
Coyote , Great news , glad to here you will be attending..
Got it! Lol I'm sure you have one friend
IRM616 is offline
Old 01-22-2012 | 11:26 PM
  #15574
Originally Posted by TEAM-AE-4-EVER
Kbmoss - Many thanks for the detailed reply! It is appreciated! So I guess the choice is to use The Pinned Shaft with a slipper pad combo of the Garodisks, HD Pads and/or Stock Slipper Pads.... OR The MTK Clutch Basket with the Garodisk, HD Pads and/or Stock Slipper Pads... to avoid the Idler Gear from getting chewed... Correct? Any suggestions on what Slipper Pad combo works best with either set-up considering the truck will be running outdoors with big jumps... and probably hard landings?
Thanks again for taking the time to share some info! I hope I can get the truck ready for testing during the week!
The truck works better overall when you have some kind of diff action going on between the F/R diffs. Pinned is not the way to go...it was just a bandaid. You would be better off going with Marcus's center ball diff in my opinion.
F_ME is offline
Old 01-22-2012 | 11:31 PM
  #15575
Smithy79's Avatar
Originally Posted by clastovica
I guess we should add whether or not we are using the dust covers I know they will limit travel by a few mm themselves. Has anyone measured the amount of up travel the dust covers take up so those that do not use them can compensate?
Chris L
Ahhhhh,
Well wouldn't ya know it, this has all come about since I installed the FT shocks without boots can't believe I didn't think of this.
Thanks for the tips guys, I'll need to compensate the up travel with limiters now that I have no boots.
I'm assuming the limiters clip to the shock shaft under the rubber ring??
Also, since upgrading my ESC motor to the RX8 Pro 4 4000kV, I've killed 2 batteries, melted the bullet socket on the positive termianls.
My C ratings are obviously not accurate? Gens Ace 5000mAh 40C & Turnigy Nanotechs.....
Any suggestions of batteries?
Everyone's help is much appreciated.
Smithy79 is offline
Old 01-23-2012 | 12:06 AM
  #15576
Cameron Kellogg's Avatar
IRM
I race with Cherry at big Northwest events. One thing we have in common is we love our AE stuff. It's always good to have another fast racer at the track to help with set-ups. We both have the same goal of putting AE on top.
Cameron Kellogg is offline
Old 01-23-2012 | 12:14 AM
  #15577
heavyjeffd's Avatar
I may be joining you guys in the PNW in the near future.
Hope I can still get my nitro fix!
heavyjeffd is offline
Old 01-23-2012 | 12:16 AM
  #15578
CoyoteSlash's Avatar
as in Moving here?
CoyoteSlash is offline
Old 01-23-2012 | 12:19 AM
  #15579
heavyjeffd's Avatar
Originally Posted by CoyoteSlash
as in Moving here?
Probably Seattle. But to me, Portland is close.
After living in Texas for 12 years, everything is close! lol
I'm driving 10hrs to go race this coming weekend.
Old 01-23-2012 | 12:21 AM
  #15580
Ah. Well welcome to the FLOOD LANDS.
Old 01-23-2012 | 12:27 AM
  #15581
Originally Posted by Smithy79
Ahhhhh,
Yes, use those clip on limiters.
As for the bullet sockets, you need to get rid of the bird cage style male bullets and use the Castle style bullets. They have much less resistance than the bird cage style. The resistance is is causing the melt down.
Any good lipo rated 50C or better should be fine. I would also suggest using at least 70% current limiting in the RX8 to keep things happy. You won't notice any issues with punch out of the hole but your electronics will run cooler and last longer.
F_ME is offline
Old 01-23-2012 | 02:26 AM
  #15582
Smithy79's Avatar
Thanks heaps
Will invest in the Castle connectors, and some new batteries. Maybe it's time to experience the saddle setup.
What size batteries are recommended for the saddle setup, mAh, brand etc? I've never seen a saddle pack before, but I'm loving the good things I've been reading here in regards to the effect the saddle setup has on the truck.
PS: My ball diff arrived today, cheers Marcus, awesome service!!!
Smithy79 is offline
Old 01-23-2012 | 05:07 AM
  #15583
Misfit138's Avatar
Ahhhhh,
With the Tekin RX8 and Pro 4 you definitely need to run your current limiter between 50-75 percent if you don't have batteries of at least 50c.
Misfit138 is offline
Old 01-23-2012 | 05:55 AM
  #15584
heavyjeffd's Avatar
I grew up on the Gulf Coast, ya'll don't know what rain is! lol
Old 01-23-2012 | 06:37 AM
  #15585
xrayrc's Avatar
anyone got any tips to get the diffs to stop leaking?
seems like every 3 races nights after rebuild diff are dry and
upon dissassembly all the oil is in the case and barely in the diff case.
I did try green slime on the orings but it has not helped.
anyone try just running grease should I change diff bearings
because outdrives wobble like crazy....
xrayrc is offline
