Like Tree5Likes
SC10 4x4 Thread
Old 01-23-2012 | 10:08 AM
  #15601
Mizchief's Avatar
Originally Posted by tom2tone
question and yes I did a search... Will a castle external BEC pro fit in the truck? I'll be using a MMP, tekin pro4 4000kv and a hitec 7955 servo. My LHS has the pro in stock but not the smaller one. Just need to know if I need to order the other one.
Thanks in advance!
Seems like overkill. The regular 10A model is more than enough and fits nice mounted to the inside wall of the esc tray or center chassis. How much do they want for the Pro? you might be able to get the regular one shipped overnight cheaper since it's so small.
I'm sure you could find somewhere to mount it, I've seen guys mount the MMP on top of the rear tranny
Mizchief is offline
Old 01-23-2012 | 11:03 AM
  #15602
Wild Cherry's Avatar
Tech Legend
Originally Posted by Mizchief
Why waste precious mAh's on pad heat when you can have a center diff putting the power where it needs to go?
Why ?
so you won't waste precious energy to wheel spin with the tires.....
Wild Cherry is offline
Old 01-23-2012 | 11:11 AM
  #15603
vito's Avatar
got tips to put sway bars on?
vito is offline
Old 01-23-2012 | 11:15 AM
  #15604
discgolferlee's Avatar
remove bumpers use supplied hardware. it's pretty straight forward
discgolferlee is offline
Old 01-23-2012 | 11:21 AM
  #15605
Misfit138's Avatar
Originally Posted by symmetricon
Unfortunatly we are still waiting for a rock solid diff that doesn't wear out quickly
Id give my left nut for a diff with hardened steel bushing in it instead of brass
Has anyone tried these? http://www.ebay.com/itm/SC10-4x4-SCF...item5ae4ab275c
Misfit138 is offline
Old 01-23-2012 | 11:22 AM
  #15606
Mizchief's Avatar
Originally Posted by Wild Cherry
Why ?
On the street yes, on the dirt it depends. If you watch one of those huge tractor pull competitions, you notice that they tires spin really fast and shoot out roost. They actually use the action->reaction effect of the dirt pushing out the back to move the tractor forward instead of actually rolling across the ground.
Same thing with a center diff on roostable dirt (I'm sure there is a better way to say that) when the wheel spins you do get some forward momentum due to the dirt being pushed out from the rear.
Mizchief is offline
Old 01-23-2012 | 11:25 AM
  #15607
Tech Legend
I got it ...
bigger the Rooster tail = more forward bite
Old 01-23-2012 | 11:33 AM
  #15608
symmetricon's Avatar
Originally Posted by Misfit138
I am currently using those, and they are ok, but they are wearing out too. Only one half of the diff case is hard anno, so the non anno side wear pretty pretty quick. Also there is other problems with the way they are designed. Several hundred pages ago, I did a revie on them detailing all the issues with them.
symmetricon is offline
Old 01-23-2012 | 11:34 AM
  #15609
MantisWorx's Avatar
Why ?
the center dif accelerates faster than without, you only spin two wheels instead of four.
MantisWorx is offline
  #15610
Why ?
Dont knock it until you try it
Old 01-23-2012 | 11:36 AM
  #15611
Misfit138's Avatar
Thanks.
Old 01-23-2012 | 12:03 PM
  #15612
Slotmachine
Thanks for taking the time give me some initial feedback, looks like Blitz tyres and 10K rear diff for a start then!, my camber link settings are;
Front Camber Link, Outside, 2mm washers
Rear Camber Link, Inside, 1mm washers, Rear hub B
Are you using the Blitz 4.5mm offset wheels as well, which compound D or S?
Thanks again
Originally Posted by Slotmachine
I race on an Asphalt track and I can tell you that if you run less than 10,000 rear diff fluid the truck gets loose. I can also recommend the HPI BLITZ stock tires on asphalt I am getting 100 runs on mine and my truck is one of the fastest there. You also don't mention your camber link locations, these are important as a long flat camber link will give you more traction.
gbyfield is offline
  #15613
Chad Smith's Avatar
With the Suburbs 2.0 will the Proline ProTrac Suspension Kit Renegade 2.2"/3.0" Black Wheels work? Just trying to make sure before I buy new tires. Thanks in advance!
Chad Smith is offline
Old 01-23-2012 | 12:14 PM
  #15614
Dano628's Avatar
IRM
I have no friends
Originally Posted by IRM616
Got it! Lol I'm sure you have one friend
I doubt he does .
Dano628 is offline
Old 01-23-2012 | 12:16 PM
  #15615
Yes as that's what I run.
jamr1130 is offline
