Like Tree5Likes
SC10 4x4 Thread
Old 12-31-2011 | 11:01 AM
  #13591
Originally Posted by CoyoteSlash
Right. I agree. I just want to make sure there isn't something making these guys choose certain turns when you can go "tap tap tap" to 80% Throttle on your transmitter and you just turned a 6.5 into a 7.5 etc. Unless i'm being a simpleton.
And on the 1415 note. I love love love that motor. It's just time for a sensored for my racing. Even if I may be hesitant due to not really believing the Sensor is helping 'that' much in our Pro 4 Class.
There is a difference between motors (6.5 vs 7.5)Yes you can turn down your radio but now you are not using your motor to its peak performance.These motors have power bands and torque curves.
http://en.wikipedia.org/wiki/Power_band.
Do your homework more is not always better.
sedemente is offline
Old 12-31-2011 | 11:04 AM
  #13592
Robert421's Avatar
Default Drive train
How tight are the drive trains in your trucks? I am finishing the build on my truck and mine feels tight. I have loosened the transmission screws front and back, tightened them down and backed off 1/2 turn. It is not so tight that I can not turn it, it just seems tight.
Robert421 is offline
Old 12-31-2011 | 11:09 AM
  #13593
the time has come to wish all a happy,healthy new year to all.......
beaven is offline
Old 12-31-2011 | 11:13 AM
  #13594
j_blaze14's Avatar
Originally Posted by JEFFs SC10
i like those wheels too just be sure to use locknuts, my wheels kept spinning off.
i thought i was the only on with that problem. seems i loose a left side wheel once a race day. locktite, teflon nut and i scored the base of the nut too.
j_blaze14 is offline
Old 12-31-2011 | 11:15 AM
  #13595
Wild Cherry's Avatar
If you mix up the Transmission screws , One screw to long & it can go though and lodge up & bind the pulleys.
Also same for rear arm mounts , ck that ...
Wild Cherry is offline
Old 12-31-2011 | 11:24 AM
  #13596
tom2tone's Avatar
Originally Posted by Jerm13
Those will work just fine. Any wheel (12mm hex) that fits the losi SCT, will fit properly on the SC10 4X4 and 2wd and vise-versa. They are the same offset. You can also use the DE Racing and Pro-Line Pro-Trac wheels.
If you run the Slash/ Blitz wheels which will widen your track width, it will help tighten the car up on loose surfaces but you may not be legal depending on which rules you ran.
So as long as they are 12mm or say they will fit losi sct? The front or rear wheels for slash or blitz won't fit correct?
tom2tone is offline
Old 12-31-2011 | 11:25 AM
  #13597
Vegatron75's Avatar
Originally Posted by MantisWorx
Vega, hit me up when you get a chance please.
ygpm
Vegatron75 is offline
Old 12-31-2011 | 11:31 AM
  #13598
Vegatron75's Avatar
I wouldn't get anything that's supposed to fit the SCT/E. The wheels for the losi have much less ribbing inside the wheel. Must be for clearance for the Losi parts.
The SC10 4x4 wheels have more ribbing to help keep the wheel true.
If it was me, I'd use the hazard Jconcepts wheels for the SC10 4x4, you'll gain a little width and have the ribbing in place.
If you really want to gain some width, run the slash fronts. A dude I race with runs slash front offset wheels. I measured the stock width, and then the slash fronts width. 30mm increase w/ the slash fronts!!!!
Too bad for him, he has no fenders on the truck, everyone thinks it lame to run the slash fronts, and I still beat him every week...... with the stock offset.......
Old 12-31-2011 | 12:00 PM
  #13599
Chad Smith's Avatar
To balance my truck in all 4 corners do I need 4 scales under each tire?
Or which is the best way to balance the truck?
Chad Smith is offline
Old 12-31-2011 | 12:08 PM
  #13600
symmetricon's Avatar
Originally Posted by Krio
For the RX8, as soon as it can get a solid read on rotor position and timing it goes to sensorless operation. If you watch the 3 LEDs on the far right that indicate the sensors are working they will shut off the same time the esc goes into sensorless mode. If I had to put a number on it it would be below 2000 rpm, but really depends on motor type and wind.
I assume you are running an RS pro then?
Xerun 120amp
symmetricon is offline
Old 12-31-2011 | 12:16 PM
  #13601
Cameron Kellogg's Avatar
Kellogg, It looks like your colors, Sterling is running that ugly thing so U know ...
I think that is why I caught my eye. Did not know anyone in the Northwest was running it yet. Working up a new look for the PNWS.
Cameron Kellogg is offline
Old 12-31-2011 | 12:23 PM
  #13602
The Pacific N/w Shoot OUT ....
Expecting a C mains maybe more for the 4x4 Sc ....
Oyeah ......
We'll have a blast kellogg....
Old 12-31-2011 | 12:32 PM
  #13603
tom2tone's Avatar
So will the hazards fit these wheels? I'm just trying to get a set of wheels for my tires. So when I order my kit I can purchase them too. Thanks.
http://www.amainhobbies.com/product_...-Truck-Tires-2
Also is the stock body good to race or should I pick another? What seems to be the most popular?
tom2tone is offline
Old 12-31-2011 | 12:42 PM
  #13604
Vegatron75's Avatar
You been drinking already?
Hazards are "wheels", So will the hazards fit these wheels? UMMMMM
ANy wheels that says it will fit the sc104x4, WIll fit the sc104x4. It ain't magic.....
Even better the link is for .....TIRES....
Here's a link to ....WHEELS...
http://www.amainhobbies.com/product_...ack-2-SC10-4x4
Bodys? what are those??????
Old 12-31-2011 | 12:47 PM
  #13605
tom2tone's Avatar
I meant to say tires... The Proline suburbs that I have. But thanks for the sarcasism. Next time I'll ask someone else
tom2tone is offline
