Like Tree5Likes
SC10 4x4 Thread
Old 12-29-2011 | 02:50 PM
  #13441
Evil Genius jr.'s Avatar
Originally Posted by Graphite07
front right shock leaking bad. i called associated he said take the shock apart and spray motor cleaner on the shock Cartridge that did nothing still leaks.
Mine too! I just installed a new cartridge but that did not help at all.
Evil Genius jr. is offline
Old 12-29-2011 | 03:13 PM
  #13442
Mac The Knife's Avatar
R/C Tech Elite Member
Originally Posted by Cameron Kellogg
I hope it will be blue.
Mac The Knife is offline
Old 12-29-2011 | 03:14 PM
  #13443
You should anodize your basket blue lol.
Are there anyways to clearance the basket without a heat gun?
Old 12-29-2011 | 03:47 PM
  #13444
I ground mine, take about half of the material out and it fit. I have ran it for 2 months now and no wear marks on the cover.
Kbmoss is offline
Old 12-29-2011 | 03:49 PM
  #13445
Wild Cherry's Avatar
Tech Legend
take the cartridge back apart
replace X rings & green slime um
install cartridge with the tapered end of cartridge up *
* this step is where most go wrong and will leak if done backwards
BTW never use motor spray on the X-rings as they will only swell & need replacement
Wild Cherry is offline
Old 12-29-2011 | 03:53 PM
  #13446
I did that however mine leaks through the threads of the gray and black parts.
Old 12-29-2011 | 04:02 PM
  #13447
Tech Legend
check the cartridge for damage on the tapered end , if the taper has been crushed , it can leak ...
Old 12-29-2011 | 04:18 PM
  #13448
that is fine also.
Old 12-29-2011 | 05:06 PM
  #13449
sandsurfer's Avatar
that is fine also.
If they are factory team shocks I found that they have some type of coating on the threads that was causing mine to leak. Took me alot of time with an awl to get it removed. Now no leaking. If they are stockers I never had a problem with leakage.
sandsurfer is offline
Old 12-29-2011 | 05:07 PM
  #13450
cbaranski's Avatar
I've been running the hard coated bodies with the gold shafts and I have had no leaking issues what so ever with my shocks. I liked these shocks so much I run them on my 2wd sc10 as well.
Chuck
cbaranski is offline
Old 12-29-2011 | 05:08 PM
  #13451
They are stock.
Old 12-29-2011 | 05:22 PM
  #13452
JEFFs SC10's Avatar
Chuck
do you have a pic of them installed? what springs do you use on the 2wd? I was thinking of doing this.
you can pm me, so we don't go o/t here.
JEFFs SC10 is offline
Old 12-29-2011 | 05:28 PM
  #13453
thebizz's Avatar
Default TSR silicone shock o-rings
Does anyone use these o-rings if so? good, bad or other>
http://www.ebay.com/itm/TSR-Pro-Seal...item2a134d325d
thebizz is offline
Old 12-29-2011 | 05:30 PM
  #13454
I have the trackstar ones. Much smoother than stock and cheaper too.
Old 12-29-2011 | 05:36 PM
  #13455
thebizz's Avatar
cool thx!
thebizz is offline
