Tekin Hotwire 3.0 Bluetooth Thread >
Like Tree18Likes
Old 06-01-2018, 04:28 PM
  #31
Kaifd3s's Avatar
Trader Rating: 136 (100%+)
What are people doing if they have a fan plugged in to the port, are you able to use the hotwire with the fan plugged in if you have a splitter if so is there a splitter cable available for purchase?
Kaifd3s is offline
Old 06-02-2018, 07:39 AM
  #32
fievel's Avatar
fievel is offline
Old 06-04-2018, 09:57 PM
  #33
Team Tekin
Randy_Pike's Avatar
You can run the fan to the receiver which is what mode people do if they need both. Generally you're only allowed to run the HW 3.0 in practice.
Randy_Pike is offline
Old 06-05-2018, 08:16 AM
  #34
Kaifd3s's Avatar
Thanks Randy, yup don't plan to run it during a race.
Randy_Pike likes this.
Kaifd3s is offline
Old 06-11-2018, 06:20 AM
  #35
Default V272
Any body having issues with their hotwire not showing any info on there app with this update on there phone. It will connect I can view data logged, it will show what esc, software version & the tabs. It will not however allow me to make changes to the esc via mobile. I can make changes with my laptop. Hotwire works fine with my other esc's that still use v258 but not v272. Trying to run app & hotwire with Samsung s9. I have tried the recommended connection procedure connect to esc first than device still nothing. Doesn't matter on esc either I have tried with rs, spec, & rsx
Rayz is offline
Old 06-11-2018, 06:26 AM
  #36
Default V272
I have also tried to uninstall & reinstall the app, power down my phone & restart it still the same result
Rayz is offline
Old 06-11-2018, 10:49 AM
  #37
Same here. I have an iphone 6 with the latest software release and did the v272 updates to both my RX8 gen 3 ESC with gen 3 blue tooth modules and neither will connect with the phone app. The message on the phone says to update the app by deleting the old one and downloading the new app but when I did this, I got the same error. The phone won't connect through the HW blue tooth app.
rock-rod is offline
Old 06-14-2018, 12:50 PM
  #38
Trader Rating: 19 (91%+)
I am getting same problem with v272 and a samsung s9....connect to blurtooth fine, can confirm connection, but cannot view or edit any of the tuning parameters, pages are just blank, can edit in PC, will try a tablet or something, but so far, v272 and my s9 have been a bust for me!
1M likes this.
boostedRN is offline
Old 06-14-2018, 06:08 PM
  #39
1M
1M's Avatar
Trader Rating: 42 (100%+)
seems the app has not been updated to allow 277 adjustments.
1M is offline
Old 06-14-2018, 09:23 PM
  #40
Was thinking the same, no dice on my other devices, reverted back to last version for now and working like a champ.
Old 06-15-2018, 06:18 PM
  #41
Team Tekin
Randy_Pike's Avatar
The app updates on both Android and IOS were delayed rolling out. They should be populating their respective apps stores any day now. This will allow them to work on the latest software.
1M likes this.
Old 06-15-2018, 09:19 PM
  #42
R/C Tech Elite Member
lowspark's Avatar
Update app on my iphone tonight (error reading that i needed to update will trying to set up a new RX8).
Worked perfect... some new settings on there to play with
lowspark is offline
Old 07-12-2018, 08:07 PM
  #43
mtveten's Avatar
Trader Rating: 28 (100%+)
Neither of my android phones (7.0 and 7.1) are working. They both are able to bind but then when I try to connect they are unable to locate the device. My ancient android 4.3 tablet seems to work fine. any sugestions?
mtveten is offline
Old 07-12-2018, 08:14 PM
  #44
BRSracing's Avatar
Trader Rating: 66 (100%+)
My guess is you are running a older version of the hotwire on your tablet that is communicating with the esc. update the hotwire via pc and then make sure apps are running the current version. i bet this will solve your issue. You have to update the hotwire itself by pc. the software is on Tekin's website. Also update the firmware on your esc, you have to do it via pc as well.
BRSracing is offline
Old 08-07-2018, 09:57 AM
  #45
boudin4evr's Avatar
Trader Rating: 18 (100%+)
THE Randy Pike, what SMALL laptop do you recommend to run hotwire 3.0? I am SO tired of lugging around this OLD crappy, huge laptop that I have been using for the last 9 years!
also, what specs? I am desperately waiting for the MAC OS stuff to work without using bootcamp or....
thanks
boudin4evr is offline
