Tekin Rx8 Gen3 Thread
#241
Ok question how common is it for a pin to break in the sensor board in the motor? I have a new motor I had mocked up in a Tekno ET48.3 build upon finishing stuff up I went to unhook the sensor wire and a pin from the motor just broke off and pulled off with the sensor wire. I am literally in shock this motor doesn't have 1min of movement on it. How common is this? Is Tekin pretty good about taken care of stuff on support side?
#242
#243
#244
Is the 1900, still the go to motor for ebuggy? I see now there are 2050kv motors but very few top level set up sheets show anything other than the 1900’s? Just more top end on the 2050’s or is it more torque as well? As if tire spin is not an issue with any 1/8 vehicle...
#245
Based on all I've read, I'm thinking the 1900 is the "go-to"...except that, what people forget to indicate when they're mentioning this is that this is ONLY true when running 4S (or higher) batteries. Most (if not all) indoor tracks don't allow anything larger than 3S...and, in most cases, only 2S. For anything less than 4S, the motor needs to be faster. As such, in the case of 2S batteries (which is all that's allowed under ROAR rules), the motor needs to be approx 4000kV. It's these "little", but HIGHLY important, details that make a huge difference.
#247
RC isn't a "one size fits all" activity, any more than cycling, skiing, it any other sport/activity. It's just like, in a thread I created elsewhere in these forums, where I was asking about the best recommended ESC/motor combos for a specific vehicle. In the thread, I very clearly indicated that the vehicle was to be for race ONLY, and that the primary track is an indoor track. I say clearly indicated that ONLY 2S is allowed. Yet, for some unknown/strange reason, almost all replies providing suggestions were such that, the motors...or, to be more accurate, the kV of the motors...suggested would have all been great IF it was an outdoor track, and IF the vehicle were running 4S. Yet, again, it was clearly indicated in the initial post that it was an indoor track, and 2S is so that's allowed.
I'm sorry if it seems like I'm "ranting"...I'm not trying to. But, the point is, there ARE different types of RCers - racers, bashers, recreational users (drug pun not intended), etc. Likewise, there are those who run indoor only, and outdoor only. There are also those who run vehicles in a specific environment - clay, dirt, sand, even snow. Every variation has speed-demon needs/requirements, and, when someone creates a thread, and specifies those requirements, posting replies that don't correlate to the specific needs of the OP don't help anyone....not the OP, not anyone participating in the same thread who needs the same info. The End.
#249
Do you not bother reading? Indoor track ONLY allow 2S. This is for safety reasons, probably due to the size of the building, as well as the businesses (automotive) that occupy the other 3/4 of the building. I don't make the rules...BUT EVERYONE who raced there IS required to comply with them.
I realize that 1900kV motor, running on 3-4S, is the "standard"...but, unfortunately for me, and everyone else who goes to this particular track, the "standard" does not fit in with the rules they have set. This also means racers who go there need two motors (approx 4000kV for that track, & others like it, and 1900kV for "standard" tracks), as well as two sets of batteries (2S for that, & similar, tracks, and 4S for "standard" tracks). I agree it's ridiculous, but it is what it is.
#250
Did not realize this was a thread specific to your situation. I figured I would ask a 1/8 motor question in the RX8 thread about if the 1900kv was still the go to motor for 1/8 outdoor racing. I saw Randy Pike is helping out so I figured it was the right area to ask. I know a lot of racers are running 2000, 2050 and 2100kv motors, but when you look at the pro setup sheets it is almost always a 1900kv? So I was trying to ask people that work for Tekin about advantages and disadvantages of the 1900-2100 motors in a 1/8 outdoor, 4 cell environment.
#251
First, you've making it sound as if I'm trying to cause problems...I'm not in trying to provide some helpful information, so that those replying to others can actually provide helpful/useful solutions.
Second, please, show me where I said anything about this being "my" situation. I, very clearly, stated that this affects everyone who goes to this track, as well as anyone who goes to tracks with similar rules. The point I was making is that, in replying to motors inquiries (in this thread, as well as all other threads), people always seem to assume that the person asking is running at an outdoor track, with no battery limitations...even when said person has clearly indicated an indoor track and/or specific battery limits...which leads to incorrect, and non-useful, information being given in their replies. It's no different than when someone inquires about something where "control" (such as where a track is involved) is the primary factor, and another person replies back telling them how to make their vehicle the fastest street racer they'll ever see (ie. a person asks about apples, and someone else telling them about pears...yes, they're both fronts, but their different kinds of fruits).
On the "plus" side, using that last example, at least the person wouldn't have told them about steaks, or veggies, as I've also seen that told of thing happen in forum threads, where someone as about...say...upgradingupgradi, and you get people responding about how the person should, instead, upgrade their steering knuckles and/or C-hubs. At least I was talking about motor vs motor.
#253
Additionally...and the primary reason I joined this particular thread... was planning on using the an RX8 in the other three vehicles I'm building, and I was hoping to find useful info as to which motor(s) to pair up with each of those ESCs - one of which happens to be a 1/8 E-Buggy, which will be running on the previously-mentioned track. In other words, it is still related.
On an entirely separate, yet related, note, in an "ideal world", there'd be a separate thread for every possible situation. However, just as an "ideal world" is unrealistic, so is the idea of all those individual threads. As such, sometimes, there is bound to be crossover. I've seen such happen countless times, in other threads on this forum, as well as on other forums. ESCs & motors are related, and, as such, those in here shouldn't have any problem if an inquiry about one leads to inquiries about the other.
RCing is supposed to be a "friendly" sport/activity. If everyone worked together to actually help one-another, instead of putting others down, more would get accomplished. I'm NOT saying your reply was putting me down (obviously, it wasn't), but there are plenty of others who seem intent on putting others down. This has been noted elsewhere in this forum. It has also been noted in other forums, about this forum, which is why numerous people have left the RC Tech forums.
85Likes
