Tekin Rx8 Gen3 Thread >
Like Tree85Likes
Old 02-05-2022 | 10:13 AM
  #391
Anyone running their RX8 on road, touring car etc?
Just after some ESC setting tips
EvilR2.0 is offline
Old 02-16-2022 | 07:24 PM
  #392
Maybe the reps from Tekin can answer this… any way to set the bec to 8.4v? Is it possible with existing hardware and just a software update?
srobert910 is offline
Old 02-18-2022 | 04:03 PM
  #393
Tekin Prez's Avatar
Team Tekin
You can set the BEC to HV 8.4V in the Rx8 with the Hotwire using PC, Android or IOS. You cannot do it directly on the unit with the buttons.
Tekin Prez is offline
Old 02-19-2022 | 01:43 PM
  #394
maybe I’m missing something, my Hotwire 3.0 setup only shows 6v or 7.4v options on a single toggle slider. Is there an update that I need to make?
Old 02-28-2022 | 12:00 PM
  #395
Tekin Prez's Avatar
Team Tekin
It says 7.4v on the setting because the is the nominal voltage of a 2s lipo and what most use to indicate that voltage range. Yes when charged they are 8.4V, but electronics can only provide what the battery voltage is minus a little voltage drop in the regulators. So a full charged battery is 8.4v and the BEC output is about 7.8V. When the battery is partially used and voltage is only say 7.6V then the BEC output is about 7.2V. It is one of the reasons we personally are not fans of high voltage BEC setting in our setups because it changes as the battery is used, and just makes the servos too darn fast anyway for good steering.
srobert910 likes this.
Old 03-04-2022 | 12:19 PM
  #396
I personally run most of my set ups at 6.0v most modern ‘decent’ servos are fast and powerful enough at that setting to require the need to go higher
EvilR2.0 is offline
Old 05-15-2022 | 04:55 PM
  #397
Default Case swap void warranty?
Quick one: just bought an RX8 gen 3 new but I want to swap the case to the black version before I solder it/set it up. Will this impact my warranty? Thanks.
Mavortium is offline
Old 05-16-2022 | 04:10 PM
  #398
Tekin Prez's Avatar
Team Tekin
Changing the case does not effect your warranty.
Old 05-16-2022 | 04:18 PM
  #399
Thanks!
Also, unrelated question for you please: I'm a big fan of Tekin and I was looking at putting an RX8 gen 3 + 2000kv truggy motor in a Tekno MT410 I'm about to build. A couple of people keep trying to sell me on the Castle MMX+1515 combo instead "because Tekin is for racing". I don't understand that logic and I was wondering if you had any thoughts please.
Old 05-25-2022 | 09:20 AM
  #400
Lordzod's Avatar
Originally Posted by Mavortium
Thanks!
Hi it all depends of your budget and if already own tekin stuff , I have been using a Tekin rx8 gen3 and motor in my mt410 and love it, no need to go with the 2000kv motor the 1900kv is good enough for me unless you want ginormous torque ( that a 1900kv will give anyway) and with all the recent firmware updates the esc is even more responsive and the brakes are amazing . Unless you want to run your truck in the wet or snow I would highly recommend the Tekin ESC it's good hardware for sure.
Mavortium likes this.
Lordzod is offline
Old 05-26-2022 | 02:08 PM
  #401
Thanks for the insight Lordzod!
[​​​​​QUOTE=Lordzod;15906893]Hi it all depends of your budget and if already own tekin stuff , I have been using a Tekin rx8 gen3 and motor in my mt410 and love it, no need to go with the 2000kv motor the 1900kv is good enough for me unless you want ginormous torque ( that a 1900kv will give anyway) and with all the recent firmware updates the esc is even more responsive and the brakes are amazing . Unless you want to run your truck in the wet or snow I would highly recommend the Tekin ESC it's good hardware for sure.[/QUOTE]
Old 06-02-2022 | 06:23 AM
  #402
Lordzod's Avatar
Default If you want to run big tires then ....
[/QUOTE]
If you want to run the new batch of belted tires then you could purchase the 2000kv truggy motors it will help with those heavy tires 👍👍
Lordzod is offline
Old 07-08-2022 | 10:04 AM
  #403
platgof's Avatar
I am having a problem with Tekin warranty. I bought the unit 20 June, 2022, and not getting a positive response.
platgof is offline
Old 07-08-2022 | 01:12 PM
  #404
platgof's Avatar
Called Tekin over 12 times yesterday and today AND NO RESPONSE.
platgof is offline
Old 07-09-2022 | 10:58 AM
  #405
It’s not warranty,they will say that it is your soldering
Shawn B is offline
