Trinity D4 17.5
Old 08-17-2015 | 01:59 PM
  #496
Teufel Racing's Avatar
[QUOTE=Franzchise;14144598]
Originally Posted by RC*PHREAK
buy a new sensor board?
I did that as soon as the issue happened. Still, for 50 dollars more I'm wondering if the certified motors are worth it. After I replace the sensor, I still have to buy another motor for my sc5m, so I was gonna put the rebuild in my sc and possibly a certified or normal d4 back in my yokomo.
In theory a Certified motor should be better than an off the shelf version of the same motor. Main reason is that one will be matched for the top % of parts (rotor, stator, sensor board). Now is it enough to be noticed by most drivers? I can't say for sure on that. You could also look at maybe getting a motor from a motor builder that should be similar or better than the certified one. I'm not sure of the certified motor has ceramic bearings, but if it doesn't, could be something to look at if you want, if you're wanting/trying to get the very most out of the motor.
Teufel Racing is offline
Old 08-17-2015 | 02:27 PM
  #497
Mudcat981's Avatar
Originally Posted by Franzchise
is a certified version worth the additional $50. Anyone who has one able to tell a difference. The only reason Im looking is, I just burned out a sensor board after one day of use on my d4.
First if the sensor went after one day you should be able to get it fixed under waranty.
Second I have 2 D4 non-cert and 3 Certified. Certified is definitly better.
Mudcat981 is offline
Old 08-17-2015 | 03:01 PM
  #498
Jpdanger's Avatar
[QUOTE=Teufel Racing;14144763]
I don't believe it does come with ceramic bearings. For the same price as a certified D4, I'd get a Fantom Pro Series. Fantom uses the same D4 motors, analyzes the components, assembles and upgrades the motor with an aluminum timing ring, ceramic bearings, teflon shims, and dynos the motor.
Would the average weekend racer notice the difference between a certified D4 and a Fantom Pro? Probably not, but if you're looking for every last drop of RPM and/or torque than I'd suggest Fantom.
Jpdanger is offline
Old 08-17-2015 | 04:18 PM
  #499
thanks for the input, I placed my order for the certrified version and am going to send in the one to be repaired under warranty. Even though I also ordered a sensor board as well.
As for the fantom, I didn't catch up to this thread until after I had placed my order. But that is something I may look into. Oh I am def trying to squeeze every bit of juice out of the motor. Even if they are friendly, there are many rivalries on the track. I just started a month ago and have been moving up in the local circuit, so many of the friendly tech advice for tweaking and such has died off and Im a better driver then tweaker at this point.
Franzchise is offline
Old 08-17-2015 | 10:40 PM
  #500
It's all good,
I think you might be able to get in touch with the guys at Fantom when the time comes and send in one of your motors to get the ceramics and a good,look over.
Old 08-18-2015 | 12:08 AM
  #501
hacker's Avatar
I've been quite skeptical of these 'motor builders'.....and there are a few around.
So lets say 'company X' orders 500 stators, rotors, sensor boards etc. They 'match' their best components, making an 'A' grade motor. Of the 500 parts, lets say only 50 are A grade. These will be handed out to 'team' drivers.
Now the other 450 motors left over, do you think they will send them back to the manufacturer? No....I don't think so! They will sell these to the average joe paying RRP.
So does it pay to be buying from 'motor builders', or just go buy an off the shelf Trinity?
hacker is offline
Old 08-18-2015 | 02:07 AM
  #502
RC*PHREAK's Avatar
Can't speak for any others but as far as fantom, they sell their premium motors and regular non-premium motors (which I think are $5 less than trinity's off the shelf motors). Will the non-premium motors be duds? Not any less than if you buy a regular non-5% trinity.
RC*PHREAK is offline
Old 08-18-2015 | 01:52 PM
  #503
racegoer711's Avatar
Originally Posted by elex300
CERTIFIED is the only way to go.
What about Certified Big Blue?
racegoer711 is offline
Old 08-20-2015 | 09:12 AM
  #504
Not ROAR legal,
But if you're not running at a place that's super strict on the ROAR stock rules, you'd probably have a beast to run.
Old 09-16-2015 | 07:12 PM
  #505
What's a good esc that will pair nice with the D4 17.5t? Also dumb question... Can I run reverse with the d4 or the esc determines that? Thanks!
CarlosRS4 is offline
Old 09-16-2015 | 08:31 PM
  #506
Cridd's Avatar
Orion R10.1. Esc determines and Orion has does have reverse.
Cridd is offline
Old 09-21-2015 | 01:36 PM
  #507
Is there a difference in power from the D4 Maxzilla to the Roar spec? I cant seem to find the kv on either.... Thanks!
Old 09-21-2015 | 04:21 PM
  #508
brainiac's Avatar
Whats the general consensus on short stack vs regular and regular vs certified for 2wd buggy?
brainiac is offline
Old 09-21-2015 | 04:50 PM
  #509
2good4you's Avatar
Has anyone ran a D4 short stack in a 4wd if so what is a good starting ratio
2good4you is offline
Old 09-22-2015 | 08:45 AM
  #510
Mudcat981's Avatar
84T spur
13.5 D4 1S - 23t pinion
17.5 D4 1S - 24t pinion
