Trinity D4 17.5
Old 08-11-2015 | 12:41 AM
  #481
Teufel Racing's Avatar
Originally Posted by wraithperth
Anyone running the ss in a 4wd buggy ?
Yup,
13.5ss in mine.
Teufel Racing is offline
Old 08-11-2015 | 01:21 AM
  #482
What about 17.5 ?
wraithperth is offline
Old 08-11-2015 | 01:56 AM
  #483
gogi108's Avatar
What about 17.5 ?
Yeh , ive seen one run , fantom version , looked very fast . I have no idea what ratio they were running though .
gogi108 is offline
Old 08-11-2015 | 02:42 AM
  #484
What about 17.5 ?
Not sure on that really,
I know a few racers that have ran a 17.5 in a wheeler, but that was for one race event. No idea what gearing they went with either. Most racers I know that run 17.5 2wd run 13.5 4wd for stock buggy racing, which is what I usually run myself. That seems to be the norm for the stock buggy classes for the most part (at least for the general area/region/tracks I usually run at). Only race event I know of that does have a 17.5 4wd buggy class is the OCRC Stock Nationals I believe. Might be other places that have that class, but I'm going to say I think that would be more of the exception vs. the norm.
Old 08-11-2015 | 04:54 AM
  #485
I'm from Australia and our stock off road class is 17.5 for 4wd and 2wd. I have tried running the ss in my yokomo bmax4 and have had overheating issues so was seeing if anyone had some success with them.
Old 08-11-2015 | 11:17 AM
  #486
Ok got ya,
Let me see if I can find some info on that.
Do you run a fan on the motor? I'm betting you'd almost have to in a wheeler.
Old 08-11-2015 | 01:10 PM
  #487
BKH
I'm from New Zealand, i run the 17.5 short stack version in my losi 22-4 and 22 2.0. our races are 6 minutes + final lap, i run it around the same gear ratio and timing in both ( around a 5.5 FDR and 58 motor timing). I do run a fan with it as it does get hot, but have been running this set up for about 6 months now with no issues. If you visit countiesrc.co.nz you can see the type of track i run on and lap times in the race results
Ben Hansen
BKH is offline
Old 08-11-2015 | 02:59 PM
  #488
gogi108's Avatar
Ben Hansen
How have u mounted the fan in the 22-4 ?
gogi108 is offline
Old 08-11-2015 | 09:42 PM
  #489
Ok cool. Yeah im running a WTF windy fan but it still heats up so much what spur pinion are you using exactly BKH ?
And do you think you are loosing punch due to the heat of the motor towards the end of your races ?
My car pretty much dies on the last lap of a 5 minute race man it has cost me some wins lol
Old 08-12-2015 | 03:21 PM
  #490
BKH
I'm using 78 spur 32 pinion which gives the 22-4 a 5.6 FDR, my motor usualy comes off around 60 degrees celcius ( 140 F ). When i first started running 4wd stock i had quite bad power fade in the last couple of laps but was using cheap low C rating batteries. I'm using Orca 4800 100C shorty packs now and that seemed to solve the problem.
BKH is offline
Old 08-17-2015 | 09:47 AM
  #491
is a certified version worth the additional $50. Anyone who has one able to tell a difference. The only reason Im looking is, I just burned out a sensor board after one day of use on my d4.
Franzchise is offline
Old 08-17-2015 | 10:54 AM
  #492
SeanKewley's Avatar
The sensor went after one day? What was the after run temp?
SeanKewley is offline
Old 08-17-2015 | 11:03 AM
  #493
RC*PHREAK's Avatar
buy a new sensor board?
http://www.teamtrinity.com/shop/inde...product_id=593
RC*PHREAK is offline
Old 08-17-2015 | 11:46 AM
  #494
It was coming off around 160. Never higher then 165.
Old 08-17-2015 | 11:49 AM
  #495
[QUOTE=RC*PHREAK;14144537]buy a new sensor board?
I did that as soon as the issue happened. Still, for 50 dollars more I'm wondering if the certified motors are worth it. After I replace the sensor, I still have to buy another motor for my sc5m, so I was gonna put the rebuild in my sc and possibly a certified or normal d4 back in my yokomo.
