Futaba 4PX
#781
Put your servo horn on.
Use the sub trim to put the horn at a 90deg angle (if that is what your instructions recommends).
Adjust the steering turn buckle (the one coming off of the servo) to centralize the steering rack.
Set the steering rods and camber links to equal lengths. It's not import if the toe-out is not spot on at this stage, it will be re-checked again later.
Adjust your steering end points to maximum throw. They should read the same figure each way or with in one or two.
Set you toe-out and camber and then re-check your maximum throw again.
Use the D/R to reduce your steering throw during a race, not the steering end points.
#787
#788
Straight from Hiro_Seiko, send them an email with the part numbers of what you are looking for, they will check stock and send back paypal info, takes about a week and a half to receive items, make sure you get the wheel adaptor if purchasing a wheel....
#789
#792
I had an issue with my 614 FF
A total stranger with a brand new 4PX had the same issue yesterday.
I have a total of two 4px's now because I thought it might be the radio.
I have done the firmware upgrades on both now.
I will be posting a 4px for sale that has been used once for $425 in the for sale section.
#795
31Likes
