Futaba 4PX
#31
Will it be left hand compatible?
Edit: Nevermind. Looks like it will judging from this picture. http://data9.blog.de/media/728/78007...5f26a07_o.jpeg
#32
#33
That means your collection of Fasst receivers will still work with the 4PX.
#35
More on the 4PX:
Presenting the New Futaba 4PX radio!
• The design of 4PX is completely changed from 4PK series
• Low steering position contribute to low center of gravity
• The weight is 15g lighter than 4PKSR
• An aluminum frame is inserted in the body to strengthen the structure
• All in one transmitter antenna (The angle can be changed)
• Transmitter weight: 555 g without batteries / 562 g with alkaline
• The response of T-FHSS system in 4PX is optimized and 30% faster than 4PKSR.
• Telemetry features can be used without delay in the response.
• 2.4GHz system - T-FHSS, S-FHSS & FASST-C2
• Following receivers can be used with 4PX: R304SB, R304SB-E, R614FS, R614FF-E, R2104GF, R204GF-E & R203GF
• QVGA3.5 inch TFT color LCD. The good quality LCD bring perfect visibility under sunshine.
• Sensor slot function (Telemetry channel) is equipped
• Up to 31 sensors can be utilized
• Equipped with Telemetry voice output
• Mixing function : 5 program mixing. 4WS mixing & Dual ESC mixing
• 40 model memory
• Left handed supported
• APA Handle extension supported
• 25mm extension adapter is equipped
• Push type button power switch
• Auto-power off function
• Vibration motor
• Earphone jack
• New high-durability stick potentiometers
• Communication port (For setting ESC, servos, sensors)
• Micro SD card slot (SDHC)
• Update able software
• High-point detectable throttle trigger
• More crisp feeling at high-point on the detectable throttle trigger. A driver recognized a high-point by touch
• Throttle trigger is movable with a 7 mm range (Same as 4PKSR, 4PLS)
• Throttle trigger shape is optimized as well as stiffness is increased
• Combination steering rubber
• Steering angle can be selected from 32 degree and 43 degree are selectable on each side (Same as 4PKSR)
• A driver can find the best directivity by the all in one antenna
• A switch can be touched by a driver body is equipped on the bottom of the transmitter edge
• A LED which shows telemetry “Disabled” is equipped (This function is intended to a race which prohibit the telemetry function)
• Two different types of throttle triggers are included (Can be easily changed by a screw)
• Two different size of grips (Option)
• Carbon handle grip (Option)
• July production (for Europe) -> August 2014 delivery
More pictures: http://kentech.blogs.se/
• 40 model memory
• Vibration motor
• Earphone jack
31Likes
