iCharger 406 DUO Charger
#616
You have to look at the end% I don't have my charger here but if you cut of at say 50% to say 5% also could be with balance detect options you have selected but it most definitely will drain a battery and make it hot if setup correctly did you increase the discharge amps?
Thanks.
#618
Looking at setting up the unit to discharge through the load bank but when I set it up its pulling the battery down to 3.5V @ 30A Amps but then when its done it goes back up to 3.9V and the battery is not even warm. I'm thinking that I may have some setting wrong but not seeing it. I can still pull out 2000mah on the gfx charger after it is done on the ichager and the battery is warm.
Could be poor connection, try different leads from the charger to the batteries and to the balance board.
#619
Made some changes to the end % from 50% to 10% and it was better and the battery was coming off warm and not bouncing back up to 3.9v but was staying closer to cut off. Will need play around more with this setting.
#620
Is there a way to reset the 406 back to factory defaults??
#621
#622
In the Lipo Charge Setup. Under Charge End Current Set, should I pick "End Current AND Detect Balance" as a general setting? Or... one of the other settings?
#623
It depends on what end current percentage you have, and what balance setting you have as to what it looks for to determine if the battery is done. The terms or and "and" are typical math terms as to which portion should be satisfied.
#624
Thanks Coke.
Time to RTM...again!
Bill
Bill
#625
Only one? I got two...LOL
Bill
Bill
#626
This weekend I was using my 406 duo and I got zapped multiple times plugging in and unplugging my batteries. I have never had a charger do this so when I got home I checked and the charger is always putting out between 24-25 volts on both channel one & two.
Am I crazy or is this not normal? I have only used this charger for 4 races. I don't make a habit of touching the leads but I have never had a charger do this before.
#627
I just checked my hyperion I've been using for 8 years and while it has a similar constant voltage on the output, you can touch the end of the deans connector and not get electrocuted. The iCharger feels at least as strong as a live 120v wire.
#628
I'll be following to relearn.
#629
Hi all,
My 406 duo will no longer charge 2s lipos on either channel. When I connect any 2s lipo it reads "connection error" It will however charge my 2s lipo Rx pack for my nitro buggy, but I use a special charge cord that uses the 4s balancing port. It does charge all other lipos without a problem such as 3s, 4s, etc. I tried a new balance adaptor but had the same result. I also tested my charge leads and they are fine. It seems that the 2s internal balancing circuit is faluty. I got it form Amain 9 months ago and they said to send it in and they will send me out a replacement right away. I did update the firmware to the latest version but that didn't help.
Any ideas before I send it in?
#630
Hi all,
