iCharger 406 DUO Charger
#631
Thanks, I checked youtube. Seems it could be a fuse blown, but apparently the fuses are soldered onto the circuit board. Time to send in for warranty. If it was out of warranty I would do the repair myself.
#632
I agree. If it's in warranty just have them do it but if not it's pretty simple if you watch that video how he get it. All you have to do is just order the right fuses for it.
#643
I had a channel 2 failure where it said the battery wasn't connected. Out of warranty so I opened up the case after watching the video on YouTube. Immediately found 2x 470 micro farad caps had burst. The fuses checked out ok so I just replaced the 2 caps with equivalents sourced from the local electronics shop. Charger has been good ever since. Very easy to spot the problem upon opening the charger up.
#645
https://www.youtube.com/watch?v=9j0fBukCo4Y
Hmmmmm...Lucky that I have two of them...Or, is it?
Bill
