iCharger 406 DUO Charger >
Like Tree70Likes
Old 03-20-2014, 03:44 PM
Default iCharger 406 DUO Charger
http://www.progressiverc.com/icharger-406duo.html
Specifications
Input voltage range: 10-30V DC
Input current limit: Total = 60A, Ch1/2 = 47A
Maximum charge power: 1400W at >23.5V (1000W max. per channel)
Charge current range: 0.05-40.0A per channel, or up to 70A in synchronous mode
Discharge power: 80W per channel, or up to 140W in synchronous mode
Maximum regenerative discharge: 1000W per channel, or up to 1400W in synchronous mode
Current drain for balancing: 1.2A per channel, or up to 2.4A in synchronous mode
USB charging port: 5V/1A current limiting protection 1.2A
Balance accuracy: 10mV
LiPo/LiIo/LiFe: 1-6 series per channel
NiCd/NiMH battery cell count: 1-25 series per channel
Pb battery cell count: 1-18 series per channel
PC Connectivity: USB port
Weight: 910g
Dimensions (LxWxD): 171x118x59 mm
Warranty: 1 year
* A cursory glance reveals that it is as powerful as the 4010, but the size of the 308. The only difference is that it does less cells vs. the 4010. This might be the perfect charger for RC Cars, unless you fly helicopters or planes, in which case the 4010 has more options.
More Pics
JiuHaWong is offline
Old 03-22-2014, 06:13 AM
Wildcat1971's Avatar
Trader Rating: 83 (100%+)
lower discharge too
Wildcat1971 is offline
Old 03-22-2014, 10:35 AM
Originally Posted by Wildcat1971 View Post
lower discharge too
Still, it is a pretty impressive unit.
Old 03-22-2014, 06:26 PM
steam's Avatar
does it come with the balance connection for 2s hard case packs? the bullet style that all packs use now.
If so do you see the voltages of the 2 cells when charging?
steam is offline
Old 03-23-2014, 08:52 AM
Grasschopper's Avatar
Trader Rating: 54 (100%+)
If it's like the 306 then no it will come with balance boards but it is easy to make the correct cable harnesses.
Grasschopper is offline
Old 03-23-2014, 11:02 AM
http://www.amain.com/product_info.ph...let-Connectors
these work well with the icharger if your packs have bullets.
Old 03-23-2014, 06:01 PM
Trader Rating: 97 (100%+)
http://www.tqracing.com/balance_&_power_cables.htm
#2211 1S and 2S iCharger 1410 Balance extension (does both) 600mm
koz47 is offline
Old 03-27-2014, 10:11 AM
kevin107's Avatar
Trader Rating: 107 (100%+)
Just ordered one from Progressive RC. Can't wait!
kevin107 is offline
Old 03-27-2014, 10:18 AM
Nice, let us know how you like it.
Old 03-27-2014, 11:27 PM
Nice......
Medicinal Coma is offline
Old 03-28-2014, 04:17 AM
Well you have to change the balance connector, but that is easy enough assuming you have the right connectors. You need one of these to make two cables as it has the same connector on each end.
http://www.progressiverc.com/icharge...nce-board.html
Old 03-28-2014, 07:20 AM
Well, it plugs right into my 4010 w/ slight sanding of the nubs on the balancing plug.
He's using the same plug on a 308.
Old 03-28-2014, 11:26 AM
Ok so you modified the connector...sure that works too. For $3 I figured I'd put the right connectors on mine.
Old 03-28-2014, 11:40 AM
Odin544's Avatar
Trader Rating: 93 (100%+)
The biggest concern is if you don't pay attention or someone else hooks your charger up for you and the balance connector gets plugged into the temp sensor port...... POOOOF! goes that channel. Why they used the same plug as a balance connector baffles me. I've seen several chargers get ruined this way so far.
Odin544 is offline
Old 03-28-2014, 11:42 AM
Matt Trimmings's Avatar
Trader Rating: 168 (100%+)
Exactly why I picked up the balance plug from amain.
Matt Trimmings is offline
