DX4R Pro
#496
Ok, just wanted to make sure. Call or email Spektrum, give full details on how many changes and adjustments you have made. They may have a solution, or may send you a new one, and you send them the old one.
#498
Also, there are some modes that even in inhibit, they still work. So, always set the setting back to stock, and then change to inhibit.
#499
Also, we have dsmr receivers starting at $30 so that gets you on the latest rf signal which is far superior and that is not too much to ask.
#500
So why don't you have a Lipo battery for this radio that is higher than just 6 volts, as I don't trust your standard battery setup, and I would not use it on a 5th scale either. Until I went to NiZN batteries, your system was not very good at all. Why didn't the factory realize that this radio does have issues at or near low voltage, in fact all Spektrum radios have issues at or near low voltage. The only fix is a higher voltage system, such as the NIZN batteries.
#502
Also regarding receivers- even before the new dsmr I refused to buy counterfeit receivers. The new sport dsmr receivers are the size of the original 3100 dsm2's for half the price.
The nizn's are great, no lipo mod needed. Even before the, been running orion aa's for years with no problems.
Add a capacitor and trouble free running of power hungry digital servos.
#503
The reason receiver prices are dropping is because the clones show just how much these things really cost. Sure the original ones are better quality, but the clones are pretty good also. When rx prices were stupid, that is when I went with the clones. I used the Blue clone, and did really well with the DX3S. So why don't people call the Hobby King products clones??? Sure, none of their stuff looks like Tekin, red color, and called Gen2, really, LOL!
#504
Yes, they look the same.
#505
I thought I was having glitching issues, but the car battery went dead on me. I am still running 6.6 volts 3 weeks later on my radio, thanks NIZN batteries. Be careful on Ebay, some jerks are trying to charge like $166 dollars for a set of batteries and a charger. The real price is around $23. One seller is showing $20.42 for both.
#508
Hey all,
I've decided to give these LiFe batteries a shot. I'm going to take the battery tray out and rewire it so these 4 cells are 2S2P which will give me 2400mah at 6.6 volts. I'll try to take detailed pics as I haven't seen anything posted anywhere yet as to how this radio comes apart.
#509
So IMO its useless to apply higher voltage than what it was designed for and in theory may burn up the circuit if it cant shunt the voltage it receives.
Also if you do decide to use the higher voltage batteries the voltage will stay at the higher voltage longer as it discharges that may be a good thing
#510
i just bought some savox servos to run in my nitro onroad 1/8 cars for this up coming season do i need to put a cap on the receiver to prevent a glitch? i will be running a life receiver 1100mah pack directly plugged into the receiver
1Likes
