Like Tree1Likes
DX4R Pro
Old 01-05-2015 | 07:07 PM
  #466
Originally Posted by mkl
for those using the NiZN batteries, how are you charging them? in the charger that I see sold with the batteries, or plugging in a wall charger to the radio?
I use the charger that came with the batteries.
uscgretired is offline
Old 01-06-2015 | 07:34 PM
  #467
platgof's Avatar
Same here, the ones that come with the battery. The green batteries and white charger, should be about $22 shipped, eBay. I think I paid $8 for a second set of batteries. When I first got them, they showed 7.1 volts after charging, nice, now around 6.9 volts. These batteries make a real difference in transmission power, and the ability not to glitch. This radio should have been designed for 5 batteries to eliminate all the problems with low voltage.
platgof is offline
Old 01-07-2015 | 05:32 AM
  #468
jmcelroy42's Avatar
http://www.amazon.com/BPI-High-Volta...MYHTQ09WKY8QPW
I got mine through Amazon, $24 for 8 batteries and charger.
jmcelroy42 is offline
Old 01-08-2015 | 07:08 PM
  #469
platgof's Avatar
So, how are they working for you? Yeah, that is quite a deal. I have had no issues with mine. Those are a different brand than what I got. The ones I got are $20.48 shipped with white charger and 4 batteries. Ebay has the ones you got for under $20 right now.
platgof is offline
Old 01-09-2015 | 06:27 AM
  #470
jmcelroy42's Avatar
They work great, love not having to worry about batteries anymore. with my nimh batteries I always had to charge them the day before going to the track or I would be worrying about them the whole day.
Old 01-09-2015 | 07:19 PM
  #471
platgof's Avatar
That is the weird thing about these, they keep their charge for a long time. I finish a race night, and still 6.5 volts, nice. Race the next week and finish with 6.3 volts, unreal. That is what I hated about NIMH batteries, once they got near 5 volts, things started happening, and not good either.
platgof is offline
Old 01-17-2015 | 08:22 PM
  #472
Emaculant's Avatar
Does anyone know a fix for the broken spring in the wheel?
Emaculant is offline
Old 01-20-2015 | 06:41 AM
  #473
sewerdog's Avatar
Default EXPO
just would like confirmation on this ,I haven't had time to check this out at the track yet: EXPO ;Positive on Spekrum slows down the response around neutral and negative speeds it up. thanks . isn't it the opposite on all other radios ?
sewerdog is offline
Old 01-20-2015 | 05:46 PM
  #474
Yes, you are 100% correct, on the Spektrum it is opposite of other radio brands when it comes to those expo settings for throttle and steering.
Positive expo = slows it down
Negative expo = speeds it up
4wd Racer is offline
Old 01-21-2015 | 08:07 AM
  #475
sewerdog's Avatar
thank you.
sewerdog is offline
Old 01-30-2015 | 09:08 AM
  #476
I ended up using the spring out of an old Futaba I had, much more bulky and will not snap the single looped end off. Still had Horizon Hobby send me a new Spektrum spring, and it is not the same as stock. It is still pretty flimsy, but uses two loops to connect instead of one.
jpcopeland1 is offline
Old 02-01-2015 | 09:35 AM
  #477
platgof's Avatar
Makes me want to order a back up spring just in case.
platgof is offline
Old 02-01-2015 | 10:52 AM
  #478
Do springs seem to be a problem with this radio? Guy at our track broke one Friday night as well. Wanted to look into upgrading but now am hesitant.
Slimrc is offline
Old 02-01-2015 | 02:52 PM
  #479
I've used mine for a year with no issues,this has got me wondering now
xxxntwv is offline
Old 02-01-2015 | 04:37 PM
  #480
Yeah I have had a original 3R and no problems for years now.
Slimrc is offline
