Like Tree1Likes
DX4R Pro
Old 12-19-2014 | 06:32 PM
  #451
hackersmovie's Avatar
Originally Posted by Mizchief
Seems you could wire them 2s2p and run all 4 batteries with increased capacity?
Now that's great thinking! I'll try to get 4 of those 1600's and wire them in 2s2P and have 3200! That should do
hackersmovie is offline
Old 12-19-2014 | 06:44 PM
  #452
Well that was easy! Found these on Ebay, $14 shipped for 4 of them, I'll give em' a shot.
Old 12-19-2014 | 08:14 PM
  #453
LosiRacer33's Avatar
Hey guys. Any word on a new version coming soon? I'm about to pull the trigger on a new DX4R to replace my DX4S but don't want to if there's something new in the works.
LosiRacer33 is offline
Old 12-19-2014 | 09:27 PM
  #454
Mizchief's Avatar
Originally Posted by hackersmovie
For me it's cost. I've run the same transmitter battery for years and only normally have to charge them once a month. Why continue to buy batteries just to toss em' in the trash when I can essentially buy one set and be done.
Plus you can top them off on race day and never worry about it going dead, or having to swap the disposable batteries early just to make sure you don't go dead during a race.
Mizchief is offline
Old 12-19-2014 | 10:13 PM
  #455
monkeyracing's Avatar
R/C Tech Elite Member
Originally Posted by bentgear
Why does everyone want the hassle of charging batteries and worrying if they will hold up on race day. Pop some Energizer Lithium Ultimates in there and use them for months.
My radio is very easy on batteries, but combined with everything else I've got running AAs, it really adds up. And how often do most of us actually dispose of them properly? Better for the wallet and the world.
monkeyracing is offline
Old 12-21-2014 | 07:22 AM
  #456
platgof's Avatar
I checked those Energizer Lithium Batteries and they start at 6.68 volts, not bad. But for the cost you can get the NIZN and be done with it. I really like the wiring diagram MRacing, sharp. Has anyone tried it yet, and what voltage would show on the screen? 7.2 V would be super. I am glad to see this new wiring diagram as the batteries should last a long while.
platgof is offline
Old 12-22-2014 | 09:38 PM
  #457
Originally Posted by eddie10
Remove the bottom 2 or 3 screws. You can then stretch it apart enough the tray will fall out. De solder the wires at the tray and put a battery connector on(jst or whatever you prefer). Lots of room for a life. I have a 2100 mah square pack in mine. Lasts for months. Lots of room.
Anyone else done this? Any complications?
robbie_gtc is offline
Old 12-22-2014 | 10:23 PM
  #458
I'd like to know too. I'm gonna either buy the LiFe AA batteries or get a LiFe pack and remove the tray.
When I do I'll do a "how to" thread, seems a lot of people want to know....
Old 12-23-2014 | 05:56 AM
  #459
i had an old 1700mah life battery lying around so i thoght i would try it on my dx4r pro, however the battery was just slightly too tall to work.
but the removal of the battery tray is easy, as previously mentioned, get the 3 screws out at the base part of the radio and one further up above the grip. you can take out even more above that which will give you a little more flex between the 2 halves.
one word of warning, watch the switch and the little tear drop insert below it. mine went flying out and had a job finding them again.
also the negative wire soldered to the AA battery tray is insanely short, so much so i dunno how they got the tray in there. i soldered in an extension to this wire so it was easier to but back in the radio tray until a source a slightly skinner life battery.
clarkie_ni is offline
Old 01-03-2015 | 08:30 PM
  #460
platgof's Avatar
Dave H mentioned the setting for response time, that the default is set at 4, so I looked at the menu and sure enough, it was set at 4, so I move it to 1 and the response time is now much quicker. I love those NiZn batteries, as it is so nice to look at the screen and see 6.9 volts, one less thing to worry about.
platgof is offline
Old 01-03-2015 | 08:40 PM
  #461
Yosh70's Avatar
What are you talking about, response time?
Yosh70 is offline
Old 01-03-2015 | 09:12 PM
  #462
Trim step from the default of 4 to 1, for finer trim adjustments, was something I posted recently. Should have no effect on response time or speed.
Dave H is offline
Old 01-03-2015 | 10:13 PM
  #463
sickpuppy1's Avatar
I've had a 2100 LIFE battery in mine for a year now. Lasts for.....well I dont know. After 3-4 weeks I charge it anyways, because it just doesnt feel right to go that long on a charge,lol, still showing 6.3-6.4 volts. but come on, thats a long time! Yes I love it. Getting the case back together for me was the biggest deal. I use a HP-FT2080-2S battery from Hyperion, Got it here.
Watch for sales, you can get it cheaper, though, I did.
sickpuppy1 is offline
Old 01-04-2015 | 06:39 PM
  #464
platgof's Avatar
I am glad I went the NiZn route as it was easy and cheap. I even bought an extra pack of batteries just in case. It is nice when I flip it on and see 6.6 volts after a night of racing. I can easily go two weeks of racing, no problem, and never be below 6 volts. I recharge at 6.2 to 6.3 volts. I noticed that all glitching goes away past 6 volts.
platgof is offline
Old 01-05-2015 | 06:04 PM
  #465
mkl
for those using the NiZN batteries, how are you charging them? in the charger that I see sold with the batteries, or plugging in a wall charger to the radio?
mkl is offline
