DX4R Pro
#257
Did you rebind after changing the frame rate because my 410 automatically changes it back to 11.1 when its bound I don't know about the knockoff rx someone else will have to answer that
#258
410 only does 11.5 and higher.
The process I use, I set the frame rate first in the radio, then bind the unit. Then when you shut off the radio and turn it back on, it tells u the rate. If it wont accept 5.5, then its not made to go that low.
#265
I'm using the sc-1268sg & SG2274 brushless. no problems with either of them, but I like the 2274 better because of the increased speed.
Also: both are powered through RX8 gen2's with the BEC set to 7.4v
#267
I had a problem with mine glitching with the 5v power limit. I use the BEC from Castle Creations and it fixed the problem. I was running a SR2000, Savox High Torque/High Speed servo. The servo which draws a lot of amps. Called Castle and they told me what it was. The BEC fixed the issue, it wasn't the receiver or the transmitter.
#268
I see people ask about aftermarket Rx throughout this thread but no replies. Does someone make one that works with Spektrum Tx? I see a warning on the spectrum site about a counterfeit one, but not sure if there are aftermarket Rx.
#269
Ok so I've made up my mind and I plan on purchasing this radio in a few months once I get the money saved up for it and another SR2000 receiver. Has anybody had issues using this radio with Savox servos and Tekin escs? Also, I plan on giving this thing a custom paint job. Does anyone have any tips on how to disassemble the radio and make sure it goes back the same way? I plan on taking lots of pics during the process.
#270
There have been several people who have posted about the aftermarket receivers. All of those posts are from pages 1-10.. Post 98 talks about the clones.
1Likes
