DX4R Pro
#287
I find it hard to understand how HK rates the Turnigy Ni-Zn AA's at 1500Mah and the ebay place you got yours from lists them at 2500MWh. I doubt its a typo but if its the same as mah, how do you fit more mah in the same package like a AA battery? The battery would have to be heavier and larger as such, no?
#289
Now back to topic: mAh and mWh are not 1:1 the same... but since Amps times Volts equals Watts (P=U*I), you could also use mWh as capacity (although I have never seen it on batteries before)... but you may not compare the numbers directly! You'd have to multiply the mAh with the voltage to get to a mWh number. In this example, you'd have to calculate with a voltage of 1.66V to get from 1500mAh to 2500mWh, which doesn't sound all that wrong to me (although it is a bit misleading, using mWh instead of the common mAh, just to have some bigger numbers... might even call it a cheap trick).
#291
I know it sounds a bit nit-picky, but in physics (and math, basically) there's a huge difference between "m" (="milli"=0.001) and "M" (="mega"=1,000,000).
#293
But why is that? The Nizn AA's will give 6.6V fully charged and of course you can re-charge them countless times. No modification necessary....
Regardless, I ordered a set last nite....4+1 spare and charger....$18 shipped.
I'm confident they'll work great but we'll see how they compare to the "Bunny" batteries.
#294
Suspended
#296
Mine fully charged show 7.1 volts on both radios I own, DX3S and DX4R. They both really light up on the better charge. The Life is better because it lasts usually for a month on a charge, nice, and costs less, but you have to pull the tray out and solder two wires, and foam pack the battery so it doesn't move around.
#297
I just slapped some 2300 mah Energizer NiMh in there and I was around 5.5 v most of the day. I think I was 5.7 v when I turned it on and then it fell to 5.5v and pretty much stayed there.
Are you guys seeing some kind of issues running between 5-5.5 volts? I was running at 4.6v with alkaline batteries that were 6 weeks old with no issues. Can't imagine why I would have issues over 5.0v
Also any word on the firmware update? Is it worth doing if I don't have that new receiver
#298
Ok guys, just got this as my first high end Radio system. I was using a stock Traxxas TQi with docking base prior to this.
How do you set up the A-F buttons?
Expo: if you want to slow down steering would you apply + or - expo? (Same with Throttle)
Any other tips/tricks I should know? I'm going to do my best to read thru this post in the meantime.
#299
Friends... what is the real world range on that Spektrum DX4??
Not close to being somekind like this one cheap Kyosho?
ein?
-Not even close to 100meters right?
ein?
1Likes
That's not a Spektrum radio
