Like Tree95Likes
Tekin RSX Thread
Old 10-26-2018 | 10:59 AM
  #1471
Talon4U2NV's Avatar
I'm with Randy, my BE in my stock buggy is little compaired to my RSX in the mod stuff.
Talon4U2NV is offline
Old 10-29-2018 | 08:57 AM
  #1472
Wildcat1971's Avatar
Originally Posted by Randy_Pike
The RS Pro BE was too big? How so?
I meant much bigger than my r1 or HW 13.5 spec esc. Mounting the switch and trying to keep it out of the driveline was a little bit of a pain. The esc ran fine though. I might end up getting another one though for 2wd spec racing. I really did like the feel of the BE. Probably sold it too quick.
Wildcat1971 is offline
Old 10-29-2018 | 01:55 PM
  #1473
On the BE does throttle frequency give you more feel throughout the stroke? I feel nothing between full and maybe quarter throttle....
Bubonic-X is offline
Old 10-30-2018 | 09:41 AM
  #1474
You running the spec-r 17.5?
Old 10-30-2018 | 09:07 PM
  #1475
carcrazy699's Avatar
Hey guys I have a b6.1d running the rsx and a 17.5 spec-r and I am having issues with it having nice punch out of the corners. I have the timing set at 48* and I have a 72 spur and 26 pinion (I think and will double check). Is there anything in the esc program I needs to check to have better punch? Speed seems fine just the low end suffers. I am new to this setup.
carcrazy699 is offline
Old 10-30-2018 | 09:17 PM
  #1476
Randy_Pike's Avatar
Team Tekin
Increase your minimum throttle to about 10-15, make sure your torque is off(10). You can also lower your drive frequency down. I'd make these adjustments in the order I listed them.
boudin4evr and Talon4U2NV like this.
Randy_Pike is offline
Old 11-01-2018 | 11:15 AM
  #1477
boudin4evr's Avatar
Professor Pike, in a spec blinky 10.5 class, (Mini truggy; TEKNO ET410) do you recommend running 2 capacitors? Why? I see some different ones also available. Stock in RSX box is either
330uf 16V or 180uf 16v.
then there's 1000-2700uf 16v al the way to 27uf 25v OR 1500uf 35v
Arcain41 and Talon4U2NV like this.
boudin4evr is offline
Old 12-14-2018 | 11:19 AM
  #1478
fievel's Avatar
Any pictures of the new Tekin RSX Pro?
mushroomed likes this.
fievel is offline
Old 12-14-2018 | 07:37 PM
  #1479
platgof's Avatar
Installed the RSX in my B5M and it flies. I put an 8.0 motor in it and was having problems with the RS. I know it is only rated to 8.5, so RSX replaces it. I think the battery could also be a suspect in this one as well and I changed it. Find out tomorrow at the track. Now I have RSX in all my 10th scale vehicles. This way I can upgrade the power anytime I want.
platgof is offline
Old 12-14-2018 | 10:41 PM
  #1480
RSX Pro....hmmm I am interested
Old 12-15-2018 | 06:48 PM
  #1481
platgof's Avatar
How many people throw that Tekin RSX capacitor as far as they can? Those things have caused me a ton of problems. Tekin needs to get rid of it and supply something with longer wires so it can be moved somewhere else. I have destroyed one RSX because of it and had a rough night today. I happened to have a Sanwa capacitor lying around with longer wires, and put it out of the way. Brilliant, isn't it.
platgof is offline
Old 12-16-2018 | 09:57 AM
  #1482
Di_spencer's Avatar
I just solder wires on mine. It is a hassle but not a big deal
Di_spencer is offline
Old 12-16-2018 | 11:26 AM
  #1483
BRSracing's Avatar
i have never had or seen a issue with the capacitor. Mounted off the back of the esc posts its a clean install out of the way. I can't think of a way to have issues with their design unless its not installed right.
BRSracing is offline
Old 12-17-2018 | 06:24 AM
  #1484
The cap itself is high quality, but it is a pain to mount. You want as little wire between the capacitor and battery posts as possible, so you can add a bit of wire to put it on the side of the esc. Just keep it to 1 inch of wire or less if possible.
Krio is offline
Old 12-17-2018 | 05:52 PM
  #1485
platgof's Avatar
They break off easily, and then shorten the esc out. Just imagine what that does to your esc and motor. There should be no bare wires that can cause this problem.
platgof is offline
