Like Tree95Likes
Tekin RSX Thread
Old 05-30-2017 | 05:06 PM
  #1321
Randy_Pike's Avatar
Team Tekin
Originally Posted by PorTX
Just drug my stuff out and the old Hotwire would not plug into the new RSX.
I will try to adjust it using the buttons on the ESC. Trying to turn the Current Limit down so there is not so much punch running MOD on a small indoor carpet track. The current setting shows 4 LED's on. So I will try it with one on.
You will need to update to the latest Hotwire software: Tekin - HotWire 2.0 Programming Device
Randy_Pike is offline
Old 05-30-2017 | 08:20 PM
  #1322
PorTX's Avatar
Done. Went to my local hobby shop/track for practice this evening. They had an adapter plug and did update my Hotwire on their computer! We then confirmed the change I made, using the buttons on the ESC, were the correct changes I wanted to make.
Using the current limit, did in fact help my lap times.
PorTX is offline
Old 05-31-2017 | 02:20 PM
  #1323
PorTX's Avatar
Just want to give a shout out to Jeremy from Tekin, for helping me with my Hotwire/computer issue! He got me up and running and was very patient with my lack of (tech) knowledge! Got all three of my RSX's updated and programmed like I wanted! Thanks again Jeremy and Tekin for great customer service!!
Casper and yzracer758 like this.
PorTX is offline
Old 06-01-2017 | 01:38 AM
  #1324
Hitokiri_2000's Avatar
Nothing better than awesome tech and product support
Hitokiri_2000 is offline
Old 06-01-2017 | 02:16 AM
  #1325
PorTX's Avatar
The issue was not the Tekin product, rather my Dell computer. Had to open my computer in the safe mode to recognize the Tekin app. The local hobby shop had used my Hotwire on their computer and updated my mod buggy so I knew it was not an issue with the Hotwire. I wanted to make similar adjustments after returning from the track, to my 4wd and stock buggy. Anyway, thanks to Jeremy, it all works like I need now!
Lap times before the adjustments were 17.8....after 16.9!!! Yep....THANKS again Tekin!!!
PorTX is offline
Old 06-11-2017 | 02:04 AM
  #1326
Hi Guys,
I had a weird one with my rsx today, in my last two finals the negative wire came unsoldered from the battery plug while connected to the battery, the rsx was hot, but not hot to touch, and the motor was luke warm, as was the battery.
I run tc mod with a 5.0 on a shortish track
20 degrees on the motor
10 boost 5k - 30k
25 turbo - .5 delay and ramp is 2
I resoldered the wire back on for the last race and it did it again, at the 4:30 mark
I checked the datalog, and most of it was missing for todays meeting, like, only 3 minutes of 25 minutes of running.
only thing that happened was my r1 fan failed during the second run (the first time the wire came off) so I removed it from the car
from what little was there, the esc didn't go above 80 degrees F
have I damaged my rsx somehow ?
ed
Edwin Pibal is offline
Old 06-12-2017 | 04:39 AM
  #1327
Originally Posted by Edwin Pibal
Hi Guys,
10 boost 5k - 30k
ed
Whenever I have a solder joint come undone at a connector, I always replace the complete plug. It usually means something has oxidized or lost tension, so there's more resistance.
What kind of plug is it?
As for the data log, it only can hold so much. You can tell the RSX to record less info using hotwire and it will be able to record for longer, but to capture an entire event isn't feasible.
Krio is offline
Old 06-12-2017 | 10:55 AM
  #1328
Randy_Pike's Avatar
Team Tekin
Hi Guys,
10 boost 5k - 30k
ed
On a shorty track you maybe over timing the can with the gearing you're using. Wires coming unsoldered means a lot of amp draw so check to assure you're using at least 12 awg wire and good connections. You can try reducing the can timing and adding it back via the ESC for more control.
Old 06-12-2017 | 09:33 PM
  #1329
its a reedy 5mm banana with the spring cage, it is a bit loose as the plug last race day had fallen out.
I shall replace it and see how I go.
thanks for the idea!
ed
Old 06-12-2017 | 09:34 PM
  #1330
Hi Randy
yes, I am using the tekin wire that came with the esc.
so if I took 10 off the motor and added 5 boost and 5 turbo ? or just 10 boost ?
thanks again!
Edwin
Old 06-13-2017 | 05:19 AM
  #1331
ed
If the plug fell out, that's definitely the culprit. Those banana style plugs lose their tension fairly quickly. I suggest using the cageless style plugs that are more solid like these:
Tekin 4mm Hi Power Bullet Connector Set (3) Male And (3) Female
Hi Randy
thanks again!
Edwin
On a short track like that, I'd just do boost. Set the end rpm between 15,000 and 20,000 and the start rpm around 5,000.
Krio is offline
Old 06-13-2017 | 05:55 PM
  #1332
thank you!
ill get some 5mm versions and try the different end rpm as well
thanks again!
Ed
Old 06-13-2017 | 07:23 PM
  #1333
Exclamation Issue with binding throttle on startup
Hi all, I recently bought a second hand SC5M which came with the RSX speedy. During my first race meet while getting ready for Q2 I turned on my TX and RX the truck was only steering. No throttle or brake however the ESC was recognising the signal due to the lights changing sequence in time with the throttle being pressed.
After about 60 sec the ESC would beep and the truck would start working normally. This was intermittent throughout the night and now its not working on throttle at all.
Checks completed so far:
* Changed Sensor cable - No change.
* Changed RX - No change.
Next I wanted to borrow a Hotwire 2 to update the software hoping htat might settle the issue.
Does anyone have any thoughts on whether its just stuffed or not.??
Cheers
Con
conza3 is offline
Old 06-14-2017 | 05:39 AM
  #1334
Cheers
Con
Sounds like the RSX won't arm because it isn't seeing a clear enough neutral signal from the radio. If you have already done the initial calibration sequence, you might need to use a hotwire to increase the neutral width setting to widen the window that the RSX considers as neutral. This feature is there to prevent the esc from applying any power unintentionally when you first turn it on.
Krio is offline
Old 06-14-2017 | 02:42 PM
  #1335
Randy_Pike's Avatar
Team Tekin
Cheers
Con
Widen your neutral width setting to 10. Re test.
