Tekin RSX Thread
#1291
#1292
Yep and it reverses the trigger operation as I said. Brake becomes forward, and accelerator is reverse/brake. When I try and do a controller calibration with the transmitter channel reversed it will only recognise throttle as the brake position, and will only continue when the brake is held for 5 seconds on the throttle setup. This is why I tried a factory reset which is supposed to clear the controller calibration but does not, and existing calibration works. I am using a dxs4s transmitter and an SR410 receiver
#1293
What I would suggest doing is selecting a new model on the radio, one that you have never used before. Then rebind the RX to that new model and then calibrate your radio and ESC. It would be a good idea also to preform a factory reset on the ESC before calibration.
#1294
Jeremy is correct, on the Spektrum leave the throttle channel to "normal."
#1295
Right, so back to my original question as we seem a little side tracked. How do I make the motor go in opposite direction when the manual says to keep the motor to esc connection A-A, B-B, C-C. It then says the radio channel must be reversed before radio calibration. Tried factory reset but it does not clear radio calibration. All LEDs light up as they should for a reset, All other motors I have had you reverse the motor windings and off you go but they are uncensored.
Everything works and is setup great on the ESC just motor direction is incorrect.
#1296
Follow Randy's suggestion. Make sure all your throttle settings are back to nominal and the recalibrate the ESC to the radio. Do not flip wires on a sensored system.
Make sure you check your trim and subtrim settings and all your end points. Trims should all be 0 and endpoints should all be 100
#1297
#1298
Thank you, now to buy a Hotwire programme connection. Had a sneaky suspicion that was the case.
#1299
A Hotwire is not required to reverse your motor direction but does provide an ESC option in reversing the motor. If you are able to, flipping the diffs in their respective diff cases may be able to get things going in the right direction.
#1300
A Hotwire is not required to reverse your motor direction but does provide an ESC option in reversing the motor. On your radio clicking the roller should bring up an options menu. Go to section called Reverse. Click that and proceed to the 'TH' then toggle it so that the Rev column is highlighted. I believe this should rotate the rotor in the direction needed for your buggy. Also if you are able to, flipping the diffs in their respective diff cases may be able to get things going in the right direction.
You can reverse the rotation of the motor without the hotwire by selecting option 7 under MT (motor type) on the speed control's built in interface. However, you will be running in dual mode which might make the motor feel less powerful. The best option is to flip the diffs so the ring gears are on the opposite side that they currently are.
#1301
Please don't use the radio reverse method to change the the motor rotation! Just one issue from this method is telling the esc to give the motor power whenever you hit the brakes. This can be extremely hard on all electronics involved.
Thanks to all who responded you've been most helpful👍
#1303
I know on brushless plane motors, if you wanted the motor to spin the opposite direction, you could just reverse two of the connections on the motor... for example, if you wire up your wires a-a, b-b, and c-c and it isn't going the direction you want, you would wire it a-a, b-c, and c-b. Does that not work on these car motors?
(forgive my ignorance, I'm a plane guy)
#1304
#1305
It works if you are running a sensorless motor (or aren't using the sensor cable on a sensored one). These sensored motors are designed to spin one way more efficiently when using the sensors to control the timing, so running the motor in reverse by swapping two wires isn't an option.
95Likes
