Tekin RSX Thread
#916
Just installed a RSX in my buggy.
After calibrating, with the transmitter at NOR, the motor runs reversed.
When i set the transmitter at REV for calibration, esc will not calibrate properly. In REV, after the neutral chime the esc only respond to full reverse, and then full throttle last.
Is there a way to reverse throttle/brake on the esc? Couldnīt find it in the manual.
#918
#919
#922
#923
#925
Hmm, thatīs an idea.
I have used a Hobbywing esc/motor until now, with the motor mounted pointing rearwards.
Now i have switched to RSX esc/Viper motor and put the motor pointing forward. Help med out here, should i switch the diffs around with this change?
#926
I'd wager yes. On a few cars that allow that style swap, they flip the diffs. Check your manual and make sure I'm right.
#928
My data logger doesn't seem to be logging data. When I select download, the status bar displays then quickly disappears and nothing is downloaded. I've tried clearing the memory through the Hotlink app and by pressing and holding the INCR button until it chimes, but that doesn't seem to be helping. This seems to occur after long periods of not downloading data. Re-updating the ESC with the current firmware seems to be a work around, but I have to restore my settings and re-calibrate the ESC to my radio.
Any ideas?
Any ideas?
#929
Any ideas?
Any ideas?
#930
250. Set up for all of them. If I go an extended period of time without downloading data, it stops recording everything. Erasing whatever died data there may be doesn't restart logging. Re flashing the firm starts it logging again.
95Likes
