SMC LIPO BATTERY THREAD >
Like Tree11Likes
Old 11-21-2013 | 04:51 PM
  #2656
aaron2u's Avatar
Originally Posted by Jake S
anyone have pics of the 5k 50c 4s and the 'shorty' 4s?
Here is a 4s installed...
aaron2u is offline
Old 11-22-2013 | 05:34 AM
  #2657
Thanks for all your guy's help, in my search for a new charger. Anyone using that pretty Trakpower charger/power supply? I know its not a PL 6 but is it something to consider?
http://www3.towerhobbies.com/cgi-bin...?&I=LXCADG&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXCADH&P=M
981PCAR is offline
Old 11-22-2013 | 05:37 AM
  #2658
Markcuda's Avatar
Thumbs down
That thing is a joke.
On one port, you can charge at 20 amps.
On the other port, 6 amp maximum, ya, tell me about it
Markcuda is offline
Old 11-22-2013 | 06:11 AM
  #2659
nitro_mt_racer's Avatar
I have 2 of them and they're great! This combination has worked great for our raceday setup. I looked at the PL6 & an Icharger prior to buying this combination and just didn't think the parallel board setup was going to work for us. But as Mark said, it's 20a on one side (full features) and 6a on the other (limited features).
nitro_mt_racer is offline
Old 11-22-2013 | 06:33 AM
  #2660
For about the same price you can get a pl6. Once you get used to parallel charging it is easy.
astarback is offline
Old 11-22-2013 | 06:38 AM
  #2661
Markcuda's Avatar
Yup, 100 for the trakpower power supply,
200 for the trakpower charger.
$175 for a Powerlab 6.
Markcuda is offline
Old 11-22-2013 | 07:16 AM
  #2662
Is the Powerlab 6 AC/DC, or DC only?
071crazy is offline
Old 11-22-2013 | 07:17 AM
  #2663
You can't parallel charge 2s & 4s packs together or lipo & life packs together so in certain situations the PL6 and parallel charging will work great...just not in our situation.
Old 11-22-2013 | 07:18 AM
  #2664
DC only
Old 11-22-2013 | 08:25 AM
  #2665
dtr's Avatar
dtr
While it is not so easy on tha packs, you can still charge 2s and 4s lipo serially.
dtr is offline
Old 11-22-2013 | 08:59 AM
  #2666
Originally Posted by WIGMAN
Are these the inboard batteries or do they have a plug on them?
I had something similar happen to me this weekend as well. I run the 4600 shorty packs in my 22SCT, the first time it happened I just thought I didn't charge the pack, then in the next heat my truck started slowing on the last lap of a 5 minute qualifier and died not long after I finished. I charged the pack and it only took 1700 mah so I knew it wasn't the pack. What I found is that my bullet plug(I use the solid ones) was a little wore and although it felt tight I replaced the bullet plug and never had any more issues. Just a thought on something to try.
Grasschopper is correct you should be balance charging at 1c at the very least, but since I have the same charger you do I know it will only do 6 amps so you are kind of stuck with that like me. I am currently trying to find a different charger that will do at least 10 amps, I sure would like one of those PL6's though.
Inboards. I have a set of balance leads and running leads for each. The running bullets are tight and show nominal wear. I checked voltage this morning and the "gave it up too early" race loser was at 3.79 and 3.82. Been charging @6A for almost 3 hours now... reads 4.19/4.20 and loaded 4900mah. I don't get it.
The PL6 comment lead to an all nighter on chargers and PS. I think I could do those, and a couple of the HP 1200s. Trying to wrap my head around the MPA setup as I run both 2s (SMC) and 4s (TP), and usually have 4 ports going on any given race day.
Boss Ross is offline
Old 11-22-2013 | 09:42 AM
  #2667
WIGMAN's Avatar
I would send Danny an email and explain to him everything you have told us here. Go to the smc webpage and the contact us will go straight to him. Danny might have some idea of what happened or is happening. He does alot of research and testing on lipo's and may have some better insight.
Like I said my bullets felt like they were tight but my issue went away after I changed them.
If you email him tell him I sent you from here, he will get back to you and probably ask more questions.
WIGMAN is offline
Old 11-22-2013 | 09:45 AM
  #2668
WIGMAN's Avatar
I am trying to understand this parralel charging thing. do you have to start all the packs at once or can you hook more up as you go. I have zero experience charging like that, I run a hitec x4 right now but it only charges at 6 amps, I want to get something that will charge at a higher rate like the pl6 but even at 2c I would not get all the packs(mine and my kids) charged up in time for the next race.
WIGMAN is offline
Old 11-22-2013 | 10:13 AM
  #2669
Grasschopper's Avatar
Look at the 308 Duo then. Dual channels and will do parallel charging like the PL6. I'm actually thinking of getting one and selling my PL6.
Grasschopper is offline
Old 11-22-2013 | 10:26 AM
  #2670
Markcuda's Avatar
Smile
Here is a parallel charging board=6 batteries at a time.
Markcuda is offline
