fdr & esc setup 7.5t/flow??
need help to find fdr for my lrp x20 7.5t and setup for my flow esc. Outdoor track with +-30meter straight line with technical inside with average laps around 18-19s per lap. Outdoor temp average around 34-38 celcius during midday. ty for help
I run an 81 / 20 so 10.53 FDR. version 3.3 on lrp flow
4.5T Mod Touring
I just bought a Flow Esc and would need some esc set up recommendations please.
Large onroad track with 40m straight 4.5T Trinity D3.5 motor Touring car with front spool Question, do I just use one of the preset profiles? If not, how do I set a custom recommended setting? Thanks |
Originally Posted by vadersing
(Post 12280519)
Large onroad track with 40m straight 4.5T Trinity D3.5 motor Touring car with front spool Question, do I just use one of the preset profiles? If not, how do I set a custom recommended setting? Thanks Motor Nosram Pure2 4.5 4dot ESC FlowHD v4 3-1-5-8-5-3-3 Roll Out 23.25mm (assume 63mm tire) |
Anyone any idea if you can purchase the bottom plastic case part of a flow?
If so a part number would be great. Thanks |
Originally Posted by steveonamission
(Post 12285900)
I just received an LRP Flow Competition ESC, and I am having second thoughts, I am only running 17.5t blinky n a B4.2 right now, but I might want to run mod in the future, how far in the future I dont know. Should I just send it back and pay the difference for the Works, or can I have it upgraded to the Works if or when I decide to run mod?
Originally Posted by Skillz_B
(Post 12292900)
Originally Posted by Sean Cochran
(Post 12296128)
The competition will handle light duty mod. LRP doesn't recommend it but we tested with a 7.5t in a 2wd buggy no issue. I would not recommend running mod on-road with it though.
Originally Posted by Mike Haynes
(Post 12296962)
Spot on Sean C. I have a comp in my 4wd buggy and it has been perfect, it does run a bit toasty though so i'd recommend the fan.
Is torque timing just a fancy name for the setting punch?
Originally Posted by Bill K
(Post 12302704)
Originally Posted by geeunit1014
(Post 12302745)
No, that would be "initial drive" or feel. Torque timing actually increases bottom end power
(Post 12302982)
So running high amounts of Initial Drive and some torque timing should give a significant amount of power out of corners ect?
Under boost angle and activation, how can "Boost trigger" be used instead of "Boost angle"?
Can this be changed? If so, how is this used? |
| All times are GMT -7. It is currently 02:09 PM. |
